Hi guys, is there any known issues I need to be aware of when doing a zfs replication over ssh between two Ubuntu 22.04 servers?
The speeds are down around 170k per step over ssh. The hardware on both servers is quite good and not reporting any load to speak of. The network reporrts about 21Gbps over iperf3 and if I do a scp from the cli it’s running 550MB/s to the other box.
If I dump the zfs send out through pv to ‘dev/null it seems to concur nothing is wrong on the sending side.
Could it just be ssh as the problem in this use case? I’ve not had this problem before.
