Backup on external disk using zrepl
Hi all, on my laptop I’ve two nvme, one of 2Tb with linux-zfs, and one of 1Tb with freebsd. Also I’ve one external nvme on a case that I’ve formatted on zfs for using how backup.
This in my situationmarco@gentsar ~ $ zpool list -v NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT backup 928G 302G 626G - - 0% 32% 1.00x ONLINE - sda2 931G 302G 626G - - 0% 32.5% - ONLINE lpool 1.80T 292G 1.51T - - 0% 15% 1.00x ONLINE - nvme-MSI_M480_PRO_2TB_511240829130000340-part3 1.80T 292G 1.51T - - 0% 15.9% - ONLINE marco@gentsar ~ $
marco@gentsar ~ $ zfs list
NAME                            USED  AVAIL  REFER  MOUNTPOINT
backup                          302G   597G   384K  /backup
backup/bsd                     9.62G   597G   384K  none
backup/bsd/freebsd-home         384K   597G   384K  none
backup/bsd/freebsd-home-marco   503M   597G   503M  none
backup/bsd/freebsd-root        9.13G   597G  9.13G  none
backup/condivise                180G   597G   180G  /backup/condivise
backup/linux                    113G   597G   384K  none
backup/linux/arch-home         23.9G   597G  23.9G  none
backup/linux/arch-root         21.0G   597G  21.0G  none
backup/linux/chimera-home      1.67G   597G  1.67G  none
backup/linux/chimera-root      13.7G   597G  13.7G  none
backup/linux/gentoo-root       31.6G   597G  31.6G  none
backup/linux/void-home         9.43G   597G  9.43G  none
backup/linux/void-root         11.4G   597G  11.4G  none
lpool                           293G  1.46T    96K  none
lpool/condivise                 178G  1.46T   178G  legacy
lpool/home                     46.2G  1.46T    96K  none
lpool/home/arch                22.7G  1.46T  19.9G  legacy
lpool/home/chimera             2.23G  1.46T  1.23G  legacy
lpool/home/fedora                96K  1.46T    96K  none
lpool/home/gentoo              11.9G  1.46T  10.3G  legacy
lpool/home/void                9.39G  1.46T  5.37G  legacy
lpool/root                     68.7G  1.46T    96K  none
lpool/root/arch                20.4G  1.46T  16.6G  /
lpool/root/chimera             15.2G  1.46T  9.61G  /
lpool/root/gentoo              24.5G  1.46T  20.6G  /
lpool/root/void                8.54G  1.46T  7.98G  /
for snapshot I’m using zrepl and follow its site I created this config:
marco@gentsar ~ $ cat /etc/zrepl/zrepl.yml
# This config serves as an example for a local zrepl installation that
# backups the entire zpool `system` to `backuppool/zrepl/sink`
# The requirements covered by this setup are described in the zrepl documentation's
# quick start section which inlines this example.
# CUSTOMIZATIONS YOU WILL LIKELY WANT TO APPLY:
# - adjust the name of the production pool `system` in the `filesystems` filter of jobs `snapjob` and `push_to_drive`
# - adjust the name of the backup pool `backuppool` in the `backuppool_sink` job
# - adjust the occurences of `myhostname` to the name of the system you are backing up (cannot be easily changed once you start replicating)
# - make sure the `zrepl_` prefix is not being used by any other zfs tools you might have installed (it likely isn't)
jobs:
# this job takes care of snapshot creation + pruning
- name: snapjob
  type: snap
  filesystems: {
      "lpool/root/gentoo": true,
      "lpool/home/gentoo": true,
  # create snapshots with prefix `zrepl_` every 15 minutes
  snapshotting:
    type: periodic
    interval: 15m
    prefix: zrepl_
  pruning:
    keep:
    # fade-out scheme for snapshots starting with `zrepl_`
    # - keep all created in the last hour
    # - then destroy snapshots such that we keep 24 each 1 hour apart
    # - then destroy snapshots such that we keep 14 each 1 day apart
    # - then destroy all older snapshots
    - type: grid
      grid: 1x1h(keep=all) | 24x1h | 14x1d
      regex: "^zrepl_.*"
    # keep all snapshots that don't have the `zrepl_` prefix
    - type: regex
      negate: true
      regex: "^zrepl_.*"
# This job pushes to the local sink defined in job `backuppool_sink`.
# We trigger replication manually from the command line / udev rules using
#  `zrepl signal wakeup push_to_drive`
- type: push
  connect:
    type: local
    listener_name: backup
    client_identity: gentsar
  filesystems: {
  send:
    encrypted: false
  replication:
    protection:
      initial: guarantee_resumability
      # Downgrade protection to guarantee_incremental which uses zfs bookmarks instead of zfs holds.
      # Thus, when we yank out the backup drive during replication
      # - we might not be able to resume the interrupted replication step because the partially received `to` snapshot of a `from`->`to` step may be pruned any time
      # - but in exchange we get back the disk space allocated by `to` when we prune it
      # - and because we still have the bookmarks created by `guarantee_incremental`, we can still do incremental replication of `from`->`to2` in the future
      incremental: guarantee_incremental
  snapshotting:
    type: manual
  pruning:
    # no-op prune rule on sender (keep all snapshots), job `snapshot` takes care of this
    keep_sender:
    - type: regex
      regex: ".*"
    # retain
    keep_receiver:
    # longer retention on the backup drive, we have more space there
    - type: grid
      grid: 1x1h(keep=all) | 24x1h | 360x1d
      regex: "^zrepl_.*"
    # retain all non-zrepl snapshots on the backup drive
    - type: regex
      negate: true
      regex: "^zrepl_.*"
# This job receives from job `push_to_drive` into `backuppool/zrepl/sink/myhostname`
- type: sink
  root_fs: "backup/linux"
  serve:
    type: local
This config create snapshots correctly, but I don’t understand when snapshts are moved on backup pool.
Someone use it?
I use zrepl for backups, including to a removable drive. Snapshots are never ‘moved’, they are copied.
The configuration you have posted requires a manual trigger to cause the push_to_drive job to run. To do that you’d run zrepl status, scroll down to the push_to_drive job, and press S to trigger the job.
Thanks so much, tomorrow I’ll try. But if I want to automatized? Can I do it?
Certainly, you can use any tool you like (cron, anacron, systemd timers, etc.) to run zrepl signal to trigger the job. I do this on laptops, triggering the job after the laptop comes out of suspend mode.
I’m very stupid. I’ve launch zrepl status and trigger push_to_drive, but I’ve this error:
║jobs                                ║│Job: push_to_drive        │
║├──backup                           ║│Type: push        │
║├──push_to_drive                    ║│        │
║└──snapjob                          ║│Replication:        │
║                                    ║│   Attempt #1        │
║                                    ║│   Status: filesystem-error        │
║                                    ║│   Last Run: 2025-01-25 10:40:24 +0100 CET (lasted 0s)        │
║                                    ║│   Problem: one or more of the filesystems encountered errors        │
║                                    ║│   Progress: [>--------------------------------------------------] 9.5 MiB / 46.3 GiB @ 0 B/s        │
║                                    ║│     lpool/home/gentoo STEP-ERROR (step 1/1, 5.5 MiB/13.6 GiB) server error: cannot create placeholder filesystem backup/linux-root/gentsar/lpool: placeholder filesystem encryption handling │
║                                    ║│     lpool/root/gentoo STEP-ERROR (step 1/1, 4.0 MiB/32.6 GiB) server error: cannot create placeholder filesystem backup/linux-root/gentsar/lpool: placeholder filesystem encryption handling │
║                                    ║│Pruning Sender:        │
║                                    ║│   Status: ExecErr        │
║                                    ║│   Progress: [>] 0/0 snapshots        │
║                                    ║│   lpool/home/gentoo ERROR: replication cursor bookmark does not exist (one successful replication is required before pruning works)                                                          │
║                                    ║│   lpool/root/gentoo ERROR: replication cursor bookmark does not exist (one successful replication is required before pruning works)                                                          │
║                                    ║│Pruning Receiver:        │
║                                    ║│   Status: Done        │
║                                    ║│   nothing to do        │
║                                    ║│Snapshotting:        │
║                                    ║│   Type: manual        │
║                                    ║│   <no details available>        │
on /var/log/zrepl.log I read this:
2025-01-25T10:51:55+01:00 [ERRO][push_to_drive][pruning][jHmm$EuX7$EuX7.LHnX.wIhD.ABEk]: : plan error, skipping filesystem prune_side="sender" err="replication cursor bookmark does not exist (one successful replication is required before pruning works)" fs="lpool/root/gentoo" orig_err_type="*errors.fundamental"
maybe problems are that my datasets aren’t encrypted. But I don’t understand how using send without encryption
It would probably be best to ask these questions in the zrepl repository or its Matrix channel.
this is my zrepl config that pushes encrypted backups to an external usb drive:
[root@endeavour ~]# cat /etc/zrepl/zrepl.yml
# - adjust the name of the production pool `system` in the `filesystems` filter of jobs `snapjob` and `push_to_derive`
global:
  logging:
    - type: "stdout"
      level:  "warn"
      format: "human"
    - type: "syslog"
      level:  "warn"
      format: "human"
jobs:
- name: snapjob
  type: snap
  filesystems: {
      "rust1<": true,
  snapshotting:
    type: periodic
    interval: 15m
    prefix: zrepl_
  pruning:
    keep:
    - type: grid
      regex: "^zrepl_.*"
    - type: regex
      negate: true
      regex: "^zrepl_.*"
- type: push
  connect:
    type: local
    listener_name: backuppool_sink
    client_identity: endeavour
  filesystems: {
      "rust1/crypt<": true
  send:
    encrypted: true
  replication:
    protection:
  snapshotting:
    type: manual
  pruning:
    keep_sender:
    - type: regex
      regex: ".*"
    # retain
    keep_receiver:
    - type: grid
      regex: "^zrepl_.*"
    - type: regex
      negate: true
      regex: "^zrepl_.*"
- type: sink
  root_fs: "zfsbackup/zrepl"
  serve:
    type: local
  • just enable the zrepl service
  • Sometimes I check zrepl status & force start the backup job with shift s if the job has errored.
  • You may want to adjust the number of snapshots that are taken (I’ve never needed them & am going to start taking them every 4 hours)
  • If you run LXD you may want to exclude some of those datasets (I just noticed they’ve screwed up my backups for a 2nd time)
Following the “ABC of backups” - I also use Vorta Backup to send backups to Borg Backup on remote storage.
Ok I’m trying. This is my zrepl.yml:
marco@tsaroo ~ $ cat /etc/zrepl/zrepl.yml
global:
  logging:
    - type: "stdout"
      level:  "warn"
      format: "human"
    - type: "syslog"
      level:  "warn"
      format: "human"
jobs:
- name: snapjob
  type: snap
  filesystems: {
      "lpool/root/gentoo-kde-systemd": true,
      "lpool/home/gentoo-kde-systemd": true,
  snapshotting:
    type: periodic
    interval: 15m
    prefix: zrepl_
  pruning:
    keep:
    - type: grid
      regex: "^zrepl_.*"
    - type: regex
      negate: true
      regex: "^zrepl_.*"
- type: push
  connect:
    type: local
    client_identity: tsaroo
  filesystems: {
      #"lpool/home/gentoo-kde-systemd": true
  send:
    encrypted: true
  replication:
    protection:
  snapshotting:
    type: manual
  pruning:
    keep_sender:
    - type: regex
      regex: ".*"
    # retain
    keep_receiver:
    - type: grid
      regex: "^zrepl_.*"
    - type: regex
      negate: true
      regex: "^zrepl_.*"
- type: sink
  root_fs: "zroot/linux/tsaroo"
  serve:
    type: local
when I launch zrepl status I get this:
║                                             ║│   Attempt #1        │
║                                             ║│   Last Run: 2025-03-15 10:58:05 +0100 CET (lasted 0s)        │
║                                             ║│   Progress: [==================================================>] 0 B / 0 B @ 0 B/s        │
║                                             ║│     lpool/root/gentoo-kde-systemd PLANNING-ERROR (step 0/0, 0 B/0 B) validate send arguments: encrypted send mandated by policy, but filesystem "lpool/root/gentoo-kde-systemd" is not encrypted                                          │
║                                             ║│   lpool/root/gentoo-kde-systemd ERROR: replication cursor bookmark does not exist (one successful replication is required before pruning works)        │
║                                             ║│   Status: Done        │
║                                             ║│Snapshotting:        │
║                                             ║│   Type: manual        │
I don’t understand what I wrong. I’m trying to use my second nvme, with freebsd, how disk backup
If i comment line encrypted I get this:
║                                             ║│   Attempt #1        │
║                                             ║│   Last Run: 2025-03-15 11:01:03 +0100 CET (lasted 0s)        │
║                                             ║│   Progress: [>--------------------------------------------------] 7.0 MiB / 44.4 GiB @ 0 B/s        │
║                                             ║│     lpool/root/gentoo-kde-systemd STEP-ERROR (step 1/1, 7.0 MiB/44.4 GiB) server error: cannot create placeholder filesystem zroot/linux/tsaroo/tsaroo/lpool: placeholder filesystem encryption handling is unspecified in receiver config│
║                                             ║│   Status: Done        │
║                                             ║│Snapshotting:        │
║                                             ║│   Type: manual        │
seems to be a bug - try:
encryption: inherit
& if this does not work - do the first replication with off (as you have been doing)
after spending several hours releasing a LOT of zfs holds & destroying all the snapshots - I’m leaning towards trying sanoid - it looks simpler to configure & will probably be less error prone (my LXD datasets have messed things up twice now with zrepl)
I think with any zfs snapshot app - you need to check your zfs holds & exclude datasets held by any other app (like LXD).
Thanks so much, I’m solved first step, now I would like to try to automized this work
in Linux there is a zrepl systemd service I enable - maybe the FreeBSD maintainers added something similar ? (or just write a script that runs zrepl daemon)
Yes, I’m using systemd service on linux and snapshots are automatic, but for send/recv options I must use zrepl status with manual operation
and if is possible I would like to create backup on another external drive. So I have snapshot on my pool and two backup on anothers to disks
Maybe I solved with automatization of send/recv
I think the zrepl service runs whatever jobs are configured in /etc/zrepl/zrepl.yml (it does on my system including the file sync)
