Hi,
I’ve got a ZFS datapool (set up in RAID 10) over 6 spinning rust disks (WD Red/Red+ - all CMR), and a system pool over 2 mirrored SSD’s, currently running on an Asrockrack C236M WS board, using the onboard C236 SATA chipset to drive the disks. All 8 ports are used. There’s no more space in the case, so I won’t be expanding the pool that way
I recently acquired a Dell PERC H310 flashed in IT mode, and I was wondering if I could gain anything with using this to drive the datapool vs the onboard controller?
I’m not using anything passthrough, so I don’t need it for that.
Thanks in advance for anyone who might know
Yes, as long as you’re certain that H310 is in IT mode. When in IT mode, the H310 is effectively an LSI 9211-8i, which means it’ll support >= 1.5GiB/sec total (meaning all ports together) throughput, where your mobo SATA controller very likely won’t support more than about 650MiB/sec total throughput.
One last question - will the device path change (ergo break my pools)? I’ve been using the by-id path so I would think not.
The scsi path would change, if you were using by-path. But the wwn and serial won’t change, so as long as you’re using one of those from by-id, nothing will change.
I’ve finally gotten round to putting the H310 in. Was remarkably painless, all zpools just came up without an issue.
It also feels faster, but … I don’t know if this is a placebo effect or not. I had not really taken any benchmarks before.
Pool topology:
datapool ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
ata-WDC_WD140EFGX-68B0GN0_Y5KYTGXC-part2 ONLINE 0 0 0
ata-WDC_WD140EFGX-68B0GN0_Y6G4J06C-part2 ONLINE 0 0 0
mirror-2 ONLINE 0 0 0
ata-WDC_WD60EFRX-68L0BN1_WD-WX61D96AX3DV-part3 ONLINE 0 0 0
ata-WDC_WD60EFRX-68L0BN1_WD-WX11DC7JHEKP-part3 ONLINE 0 0 0
mirror-3 ONLINE 0 0 0
ata-WDC_WD120EFBX-68B0EN0_5QJ4E4ZB-part2 ONLINE 0 0 0
ata-WDC_WD120EFBX-68B0EN0_5QJJ908B-part2 ONLINE 0 0 0
logs
mirror-1 ONLINE 0 0 0
ata-INTEL_SSDSC2BA100G3R_BTTV335209Y0100FGN-part2 ONLINE 0 0 0
ata-INTEL_SSDSC2BA100G3R_BTTV3343004X100FGN-part2 ONLINE 0 0 0
(the logs vdev is there to offload some sync NFS writes)
I doubt it’s just placebo; six decent-spec rust drives in mirror vdevs is already more than enough to blow past the throughput cap on generic mobo SATA for some workloads.
