I am building a home media server from a decade old Supermicro 4u and 8x 14GB SAS drives,
Host is a clean install of Debian 12 bookworm with XFCE,
Debian does not ship with OpenZFS , but it is available from repository, I lifted installation instructions from ZFS - Debian Wiki, I assume this the best method/repository to use with bookworm? also referencing ZFS tuning cheat sheet – JRS Systems: the blog
First step appending “contrib non-free” to all 6 entries in /etc/apt/sources.list
#install ZFS utilities from backports
sudo apt update
sudo apt install linux-headers-amd64
sudo apt install -t buster-backports zfsutils-linux
#Create ZFS pool, and my first real question why does ls -l /dev/disk/by-id/ list my drives twice? HBA thing?
#do I want scsi-3 or wwn-0x prefix on the ID??
zpool create ocean raidz2 scsi-35000cca2ad1aaff8 scsi-35000cca2ad1aca44 scsi-35000cca2ad1aed0c scsi-35000cca2ad1af534 scsi-35000cca2ad1af928 scsi-35000cca2ad1afe4c scsi-35000cca2ad1afef4 scsi-35000cca2ad1b0318
#vs
zpool create ocean raidz2 wwn-0x5000cca2ad1aaff8 wwn-0x5000cca2ad1aca44 wwn-0x5000cca2ad1aed0c wwn-0x5000cca2ad1af534 wwn-0x5000cca2ad1af928 wwn-0x5000cca2ad1afe4c wwn-0x5000cca2ad1afef4 wwn-0x5000cca2ad1b0318
#should I set -o ashift=12 or just trust that ZFS will see my 4k sectors automatically?
#disable recording of access time
zfs set atime=off ocean
#enable lz4 compression
zfs set compression=on ocean
#create datasets
mkdir -p /dataset
zfs create -o mountpoint=/dataset ocean/dataset
#set large record size for large files
zfs set recordsize=1M ocean/
BOM
Supermicro SC846B 24 drive bay Chassis
X9DRI-LN4F + motherboard
E5-2695 Ivy Bridge 12 cores 24 threads x2
256GB EEC DDR3 Samsung M393B2G70QH0-YK0 16GB x16 sticks
HBA 2008 chip-set LSI SAS9220-8i, H3-25097-03B, in IT mode
BPN-SAS2-846El1 Backplane
x2 800W quiet “SQ” power supplies
OS drive: 1TB Samsung 860 Evo 2.5" SSD on SATA 0 Btrfs
8x 14TB WD Ultrastar DC HC530 WUH721414AL4204 0F31021 Single Port SAS 4Kn, single Vdev 8x Z2
1x tested cold spare identical 14TB drive
VGA monitor, Matrox onboard video
USB mouse & Keyboard
Target performance: 1Gb LAN, 1-2 video streams, near future possible upgrade to better switch to leverage 4x 1Gb link aggregation, may need a GPU for trans-code. standard NAS duties over NFS.
drive/HBA/baackplane performance is good at 2.2GB/s peak in Badblocks.
