Hello. I don’t normally encounter issues with my media server, as I don’t use it too often (maybe 2-4 times a week to watch some shows or a movie). It’s never on more than 6 hours in one day (I’m not ready yet for the 24/7 electric bills).
I have a raidz2 setup that I eventually plan to upgrade to minimize the amount of drives I currently have but at the moment, I still need my server to work to add more media to it but also ensure that it will be working when I do start the upgrade process.
My current issue is that one of my drives are degraded. It’s showing some errors but that’s it. The status claims that it’s resilvering but it has never moved past 0.04%. Now, I’m assuming it’s taking as long as it’s taking due to the amount of drives I have, but since I have only had degraded drive issues 3 times in the 6 years that I’ve had a server (this being the 3rd), I don’t fully know all the options I have. The last two times, I just bit the bullet and bought a new drive but with the current prices for a 4TB drive, I wanted to weigh out options and troubleshooting steps before spending more money. Lastly, when I try to do any commands regarding scrubbing, resilvering or unmounting the pool, I get the error regarding the I/O being suspended, so it can’t do anything.
My current server rig specs:
raid2z: 4TB x12 (somewhere in the range of 40TB of usable space)
I’m not in front of my server but I’m using up anywhere between 25 and 30TB of that space. IT could be less but I don’t fully remember.
I also have them connected to an LSI 9300-16i. I tried updating the BIOS as a way to potentially troubleshoot the matter. I was able to upgrade it, but I assume no one would have assumed that would help. It was done as more of a curiosity.
I’ve tried leaving the machine on (3 different times) for up to 3 days without shutting it down to see if it needed that time to resilver everything, but either the percentage never moved or the next times that I would try this, it would either say 0% was scanned (at different mb speeds) or the most was 0.04%. I also tried the clear pool command to see if that would help. It did but not enough ti improve the resilvering process.
Is there anything else I can try before replacing the drive outright? I plan to obtain logs today after work but I don’t know if I know what to look for when doing that. Would anyone before to assist with what information I would need to look for? Which logs?
I did make sure to check the sectors of all of the drives prior to me initially creating this pool, which I didn’t do with my previous setup (2TB x16)
Also, Are there specific settings and configurations I can use when setting up ZFS that I should be mindful of (when I upgrade)?
Thank you in advance.
