Looking to ensure I’ve done this all properly.
I have these datasets using native ZFS encryption:
tank/rootData
tank/rootData/child1
tank/rootData/child2
tank/rootData/child3
For some non-nested dataset, I would use syncoid to replicate to a different pool like this:
syncoid -r --sendoptions="wp" tank/otherStuff backup/otherStuff
The w option doing a raw send to preserve encryption, and the p option to preserve dataset properties on the target.
When I try this same approach with nested datasets, I ran into two issues.
- Syncoid would give errors when trying to send to another pool using a command like the above. The sync snapshot would differ across the child datasets, causing issues (I think?).
- The
encryptionrootwould be incorrect on the target datasetbackup/rootData/child1,backup/rootData/child2,backup/rootData/child3.
Based on what I learned from this GitHub issue for sanoid/syncoid, I ended up with this sanoid config:
sanoid.conf snippet:
[tank/rootData]
recursive = zfs
use_template = myProd
The recursive = zfs bit is to ensure the snapshots taken by sanoid are atomic (I think?) across all the parent and child datasets. And I end up with snapshots looking like this:
# zfs get -r -t snap tank/RootData
tank/rootData@autosnap_2024-10-12_22:00:11_hourly
tank/rootData@autosnap_2024-10-12_23:00:11_hourly
tank/rootData/child1@autosnap_2024-10-12_22:00:11_hourly
tank/rootData/child1@autosnap_2024-10-12_23:00:11_hourly
tank/rootData/child2@autosnap_2024-10-12_22:00:11_hourly
tank/rootData/child2@autosnap_2024-10-12_23:00:11_hourly
tank/rootData/child3@autosnap_2024-10-12_22:00:11_hourly
tank/rootData/child3@autosnap_2024-10-12_23:00:11_hourly
Every snapshot across parent and child happens at the same time, not milli-seconds apart.
Then, I can run syncoid like this:
syncoid --sendoptions="Rwp" --no-sync-snap tank/rootData backup/rootData
Removing the syncoid recursion flag -r and instead relying on ZFS with --sendoptions=R to transfer tank/rootData and all its child datasets to the target. I think (?) I need the --no-sync-snap option because the sync snaps taken by sanoid are not atomic and the zfs send/recv seems to toss off errors if I don’t do this.
My goals with this are:
- Syncoid should replicate the parent and child datasets to a backup target.
- Preserve the
encryptionrootand other properties on the target pool/dataset.
Am I making any mistakes? Is there a better approach to sending encrypted, nested datasets between pools?
