I had some errors in my pool, as reported here: How do I determine if the device needs to be replaced
I took some time to apt upgrade && reboot now while awaiting an answer.
Today I decided to go ahead and replace the failing disk, and the errors is gone:
$ zpool status
pool: bigdata
status: Some supported and requested features are not enabled on the pool.
The pool can still be used, but some features are unavailable.
action: Enable all features using 'zpool upgrade'. Once this is done,
the pool may no longer be accessible by software that does not support
the features. See zpool-features(7) for details.
scan: scrub repaired 0B in 10:34:20 with 0 errors on Sun Sep 10 10:58:21 2023
NAME STATE READ WRITE CKSUM
bigdata ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
wwn-0x5000cca099cf2fb7 ONLINE 0 0 0
sdh ONLINE 0 0 0
sdb ONLINE 0 0 0
sdi ONLINE 0 0 0
sdf ONLINE 0 0 0
sda ONLINE 0 0 0
sde ONLINE 0 0 0
wwn-0x5000cca252e69d40 ONLINE 0 0 0 <- this had errors
sdk ONLINE 0 0 0
sdd ONLINE 0 0 0
sdc ONLINE 0 0 0
Just to be sure, I grepped my fish history, and I never zpool cleared.
Are scrub errors usually lost across reboots? Or is this due to the upgrade?
I am confuesed.
