In case this may be helpful to anyone… I have published a Vagrant box for FreeNAS 13.
VAGRANTFILE_API_VERSION = "2"
# Changes the default IP from 192.168.56.15
private_ip = "192.168.55.10"
##-- Global config -------------------------------------------------------------
Vagrant.configure(VAGRANTFILE_API_VERSION) do |config|
# Disable the synced folder (no Guest Additions on image)
config.vm.synced_folder '.', '/vagrant', disabled: true
##-- Machine -----------------------------------------------------------------
config.vm.define "truenas" do |truenas|
truenas.vm.box = "victorbrca/TrueNAS-13.0-U5.3"
truenas.vm.network "private_network", ip: private_ip
truenas.vm.provision :shell, :run => 'always', :inline => "ifconfig em1 inet #{private_ip} netmask 255.255.255.0"
##-- Provider --------------------------------------------------------------
truenas.vm.provider "virtualbox" do |vb|
# Use internal DNS from host
vb.customize [ "modifyvm", :id, "--natdnshostresolver1", "on" ]
vb.name = "TrueNAS13"
vb.memory = "2048"
end
end
end
