tl;dr
I’ve set up a small homeserver (Wyse 5070) with zfsbootmenu on Ubuntu 24.04. I’m now trying to set up remote access so I can boot it without having to plugin a keyboard - instead I want to just ssh to it.
I’ve read the zfsbootmenu docs a couple of times and I feel there’s a couple of bits of missing context in there somewhere. Has anyone successfully done this or can point me at end-to-end step-by-step docs about how to do this?
Full Details
I’m trying to build using the container and the zbm-builder.sh
wrapper script from the GitHub - zbm-dev/zfsbootmenu: ZFS Bootloader for root-on-ZFS systems with support for snapshots and native full disk encryption repo. I have:
Then I’ve read the remote access docs but they seem to sometimes be talking about a local install of dracut and sometimes using the container. Also, the container does not seem to have dracut-crypt-ssh
installed and I haven’t worked out an option to pass to the helper script that will install that package.
So if anyone can point me at step-by-step instructions that would be lovely
If not, I’m wondering about:
- forking the zfsbootmenu repo
- editing the Dockerfile to install
dracut-crypt-ssh
- building the docker image
- setting up the various config files
- this is a bold statement, but I think I’ve got most of it set up
- running
./zbm-builder.sh -i my_image_name
Does that sound like a reasonable approach? Are there some options I’m missing? Should I just post this as a github issue?
All input welcome. And if I get none I’ll keep plugging away and come back and write up what I did. Then at least future me can find it via google to work out what the hell I did when I actually got it to work. And maybe someone else will find it useful too.
You don’t have to build it yourself - you can use one of the EFI images in the Releases directly. The container is to build the image, not actually use zfsbootmenu …
Dracut is used to built the initrd for your system to pair with your selected kernel. Ubuntu defaults to using initramfstools for initrd management, but dracut and drop right into place instead. Dracut is somewhat simpler I think.
Anyway, once you have a zfsbootmenu EFI image, whether you build it yourself or download it, your system needs a way to actually boot it. Generally you put it in a UEFI partition of your disk (type EF00) and your UEFI system bios will find and boot it. From that point zfsbootmenu does its thing, scanning for zfs datasets with kernels etc that it can present for booting.
For remoting in via ssh, you will need Dropbear installed along with some dracut modules. Which means you will likely need to build your own. My own builder (GitHub - Halfwalker/ZFS-root: Set up root-on-zfs using whole disk, with dracut and zfsbootmenu) contains the following for setting it up
mkdir -p /etc/cmdline.d
if [ "${DROPBEAR}" = "y" ] ; then
echo "------------------------------------------------------------"
echo " Installing dropbear for remote unlocking"
apt-get install --yes dracut-network dropbear-bin
rm -rf /tmp/dracut-crypt-ssh && mkdir -p /tmp/dracut-crypt-ssh
cd /tmp/dracut-crypt-ssh && curl -L https://github.com/dracut-crypt-ssh/dracut-crypt-ssh/tarball/master | tar xz --strip=1
##comment out references to /helper/ folder from module-setup.sh
sed -i '/inst \"\$moddir/s/^\(.*\)$/#&/' /tmp/dracut-crypt-ssh/modules/60crypt-ssh/module-setup.sh
cp -r /tmp/dracut-crypt-ssh/modules/60crypt-ssh /usr/lib/dracut/modules.d
echo 'install_items+=" /etc/cmdline.d/dracut-network.conf "' > /etc/zfsbootmenu/dracut.conf.d/dropbear.conf
echo 'add_dracutmodules+=" crypt-ssh "' >> /etc/zfsbootmenu/dracut.conf.d/dropbear.conf
# Have dracut use main user authorized_keys for access
echo "dropbear_acl=/home/${USERNAME}/.ssh/authorized_keys" >> /etc/zfsbootmenu/dracut.conf.d/dropbear.conf
# With rd.neednet=1 it will fail to boot if no network available
# This can be a problem with laptops and docking stations, if the dock
# is not connected (no ethernet) it can fail to boot. Yay dracut.
# Network really only needed for Dropbear/ssh access unlocking
# Since we chose to use Dropbear, in this block set neednet=1
echo 'ip=dhcp rd.neednet=1' > /etc/cmdline.d/dracut-network.conf
else
# Not using Dropbear, so set neednet=0
echo 'install_items+=" /etc/cmdline.d/dracut-network.conf "' > /etc/zfsbootmenu/dracut.conf.d/network.conf
echo 'ip=dhcp rd.neednet=0' > /etc/cmdline.d/dracut-network.conf
fi
Hmm, I think it’s time to check my mental model. Having followed the ubuntu zfsbootmenu with ZFS encryption guide, my understanding is that:
- zfsbootmenu produces a
xyz.EFI
file that can be put in /boot/efi/EFI/...
which means UEFI boot will work.
- encrypted zfs root means everything outside of
/boot/efi/
will be encrypted - so you need to enter the boot password into zfsbootmenu before you can read anything else.
- the initramfs is in files named
/boot/initrd.img*
- so these cannot be read before the encryption password is entered.
- dracut is a tool used to generate initramfs images.
Given that, if I use dracut on the system itself to create an initramfs that runs dropbear to listen for a password that doesn’t help me - because the initramfs I’ve generated is in /boot/
and so is encrypted and cannot be read until the encryption password has been entered.
Therefore I came to the conclusion that I need to bake dropbear into the xyz.EFI
image, by making a custom zfsbootmenu image.
But you saying “you don’t have to build it yourself” makes me suspect that my mental model is incorrect/incomplete.
So if you (or anyone else) could explain where I’ve gone wrong that would be lovely Just assume I’m a simple sys admin who’s only used ext4 and LUKS and has never delved into the initramfs world before.
(And it’s been a while I know, life got in the way and I’m just picking up this project again.)
zfsbootmenu has the facility to request and use a password to unlock zfs native encryption. I use it now, and it works great. For LUKS you would add a helper script.
Have a look at GitHub - Halfwalker/ZFS-root: Set up root-on-zfs using whole disk, with dracut and zfsbootmenu
My setup handles both zfs native and LUKS encryption, with or without Dropbear.
Thank you again.
I’ve spent a little while looking at the script and it’s a little hard to get the big picture (no criticism when you’ve obviously spent quite a bit of work on what is now a rather long bash script).
A couple of questions about the big picture:
- is
dracut
run to create the initramfs image on the host system, or within the zfsbootmenu container?
- it looks like it’s run on the host, but I wanted to be sure.
- Can the zfsbootmenu EFI image read the initramfs before you enter the encryption password?
- I would assume not. But as far as I can tell, the dropbear stuff is included by dracut. And dracut creates the initramfs. So if dropbear is going to run before the encryption password is entered, and dropbear is installed into the initramfs, then the initramfs must be available to zfsbootmenu, and so can’t be encrypted. Is that correct?
- I’m using zfs native encryption rather than LUKS in case that makes a difference.
Thanks again for your help so far.
Dracut is run on the host to create the main host initrd images. You could use initramfstools or whatever for that, but I found that dracut is pretty nice and modular to include things.
zfsbootmenu can’t read anything in the dataset if it’s encrypted. It notices the encryption, then prompts for a passphrase. Once it has that it can unlock and look inside the dataset to see if there is a /boot directory that contains typical kernel/initrd files.
Dropbear can be included with zfsbootmenu, and it run alongside zfsbootmenu - it is not included in the main system initrd image. That allows the ssh access to enter an encryption passphrase.
Check Remote Access to ZFSBootMenu — ZFSBootMenu 2.2.2 documentation
