Preface:
Please know that before creating this post I did my absolute best to not bother you fine folks with this request, scoured the forums, tried some fixes….then tried all the fixes and I am still at the same spot as I started
It should also be noted that I BARELY know what I am doing in comparison to a lot of you, so take that for what it is.
Problem:
I have very slow download with perfect upload speeds on both the host and client machines.
The same problem persists when a NIC is directly passed through to a client machine and is persistent across all VM’s regardless of OS
The host hardware was used previously with no issue
Steps taken so far with no improvement:
Verified full GbE connection between switch and host
Changed NIC and cables
Re-Install of PVE
Directly passed a wireless intel nic to multiple VM’s, same issue
Directly passed a Realtek wired nic to multiple VM’s, same issue
Changed MTU size (its back to 1500 now)
Added pre-up ethtool -K enp39s0 rx off tx off to network interfaces
Added processor.max_cstate=1 to grub
The last three were buried in some forum posts so I tried them.
I also have pasted below some information that was requested in other posts
I know it’s going to be something with the host machine, I just don’t know what…
Any help would be greatly appreciated as I really did try to learn and solve this on my own, however I just don’t think I am quite there yet.
TIA
Host Machine
Ryzen 5600x
48gb DDR4 ram
MSI MPG X570 Mobo
PVE Version
root@proxmox:~# pveversion -v
proxmox-ve: 8.1.0 (running kernel: 6.5.13-5-pve)
pve-manager: 8.1.10 (running version: 8.1.10/4b06efb5db453f29)
proxmox-kernel-helper: 8.1.0
proxmox-kernel-6.5.13-5-pve-signed: 6.5.13-5
proxmox-kernel-6.5: 6.5.13-5
proxmox-kernel-6.5.11-8-pve-signed: 6.5.11-8
ceph-fuse: 17.2.7-pve2
corosync: 3.1.7-pve3
criu: 3.17.1-2
glusterfs-client: 10.3-5
ifupdown2: 3.2.0-1+pmx8
ksm-control-daemon: 1.5-1
libjs-extjs: 7.0.0-4
libknet1: 1.28-pve1
libproxmox-acme-perl: 1.5.0
libproxmox-backup-qemu0: 1.4.1
libproxmox-rs-perl: 0.3.3
libpve-access-control: 8.1.3
libpve-apiclient-perl: 3.3.2
libpve-cluster-api-perl: 8.0.5
libpve-cluster-perl: 8.0.5
libpve-common-perl: 8.1.1
libpve-guest-common-perl: 5.0.6
libpve-http-server-perl: 5.0.6
libpve-network-perl: 0.9.6
libpve-rs-perl: 0.8.8
libpve-storage-perl: 8.1.5
libspice-server1: 0.15.1-1
lvm2: 2.03.16-2
lxc-pve: 6.0.0-1
lxcfs: 6.0.0-pve2
novnc-pve: 1.4.0-3
proxmox-backup-client: 3.1.5-1
proxmox-backup-file-restore: 3.1.5-1
proxmox-mail-forward: 0.2.3
proxmox-mini-journalreader: 1.4.0
proxmox-offline-mirror-helper: 0.6.5
proxmox-widget-toolkit: 4.1.5
pve-cluster: 8.0.5
pve-container: 5.0.9
pve-docs: 8.1.5
pve-edk2-firmware: 4.2023.08-4
pve-firewall: 5.0.3
pve-firmware: 3.11-1
pve-ha-manager: 4.0.3
pve-i18n: 3.2.1
pve-qemu-kvm: 8.1.5-4
pve-xtermjs: 5.3.0-3
qemu-server: 8.1.1
smartmontools: 7.3-pve1
spiceterm: 3.3.0
swtpm: 0.8.0+pve1
vncterm: 1.8.0
zfsutils-linux: 2.2.3-pve
grub
#If you change this file, run ‘update-grub’ afterwards to update
#/boot/grub/grub.cfg.
#For full documentation of the options in this file, see:
#info -f grub -n ‘Simple configuration’GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR=lsb_release -i -s 2> /dev/null || echo Debian
GRUB_CMDLINE_LINUX_DEFAULT=“quiet amd_iommu=on processor.max_cstate=1”
GRUB_CMDLINE_LINUX=“”#If your computer has multiple operating systems installed, then you
#probably want to run os-prober. However, if your computer is a host
#for guest OSes installed via LVM or raw disk devices, running
#os-prober can cause damage to those guest OSes as it mounts
#filesystems to look for things.
#GRUB_DISABLE_OS_PROBER=false#Uncomment to enable BadRAM filtering, modify to suit your needs
#This works with Linux (no patch required) and with any kernel that obtains
#the memory map information from GRUB (GNU Mach, kernel of FreeBSD …)
#GRUB_BADRAM=“0x01234567,0xfefefefe,0x89abcdef,0xefefefef”#Uncomment to disable graphical terminal
#GRUB_TERMINAL=console#The resolution used on graphical terminal
#note that you can use only modes which your graphic card supports via VBE
#you can see them in real GRUB with the command `vbeinfo’
#GRUB_GFXMODE=640x480#Uncomment if you don’t want GRUB to pass “root=UUID=xxx” parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true#Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY=“true”#Uncomment to get a beep at grub start
#GRUB_INIT_TUNE=“480 440 1”
ethtool
root@proxmox:~# ethtool enp39s0
Settings for enp39s0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Auto-negotiation: on
master-slave cfg: preferred slave
master-slave status: slave
Port: Twisted Pair
PHYAD: 0
Transceiver: external
MDI-X: Unknown
Supports Wake-on: pumbg
Wake-on: d
Link detected: yes
etc/network/interfaces
#network interface settings; autogenerated
#Please do NOT modify this file directly, unless you know what
#you’re doing.#If you want to manage parts of the network configuration manually,
#please utilize the ‘source’ or ‘source-directory’ directives to do
#so.
#PVE will preserve these directives, but will NOT read its network
#configuration from sourced files, so do not attempt to move any of the PVE managed interfaces into external files!auto lo
iface lo inet loopbackiface enp39s0 inet manual
iface wlp41s0 inet manualiface enp41s0 inet manual
auto vmbr0
iface vmbr0 inet static
address 192.168.1.200/24
gateway 192.168.1.1
bridge-ports enp39s0
bridge-stp off
bridge-fd 0source /etc/network/interfaces.d/
Iperf from physical machine on the network to host
accepted connection from 192.168.1.200, port 45062
[ 5] local 192.168.1.213 port 5201 connected to 192.168.1.200 port 45068
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.00 sec 10.6 MBytes 89.2 Mbits/sec
[ 5] 1.00-2.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 5] 2.00-3.00 sec 11.0 MBytes 92.3 Mbits/sec
[ 5] 3.00-4.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 5] 4.00-5.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 5] 5.00-6.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 5] 6.00-7.00 sec 11.0 MBytes 92.2 Mbits/sec
[ 5] 7.00-8.00 sec 10.7 MBytes 89.8 Mbits/sec
[ 5] 8.00-9.00 sec 11.0 MBytes 92.4 Mbits/sec
[ 5] 9.00-10.00 sec 11.0 MBytes 92.5 Mbits/sec
[ 5] 10.00-10.05 sec 593 KBytes 92.7 Mbits/sec
[ 5] 0.00-10.05 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-10.05 sec 110 MBytes 91.8 Mbits/sec receiver
Iperf from host to physical machine on the network
Connecting to host 192.168.1.213, port 5201
[ 5] local 192.168.1.200 port 45068 connected to 192.168.1.213 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 12.0 MBytes 101 Mbits/sec 0 220 KBytes
[ 5] 1.00-2.00 sec 11.0 MBytes 92.4 Mbits/sec 0 220 KBytes
[ 5] 2.00-3.00 sec 11.0 MBytes 92.4 Mbits/sec 0 220 KBytes
[ 5] 3.00-4.00 sec 11.0 MBytes 92.4 Mbits/sec 0 220 KBytes
[ 5] 4.00-5.00 sec 11.0 MBytes 92.4 Mbits/sec 0 220 KBytes
[ 5] 5.00-6.00 sec 11.0 MBytes 92.4 Mbits/sec 0 220 KBytes
[ 5] 6.00-7.00 sec 11.0 MBytes 92.4 Mbits/sec 0 220 KBytes
[ 5] 7.00-8.00 sec 10.6 MBytes 88.9 Mbits/sec 0 220 KBytes
[ 5] 8.00-9.00 sec 11.0 MBytes 92.4 Mbits/sec 0 220 KBytes
[ 5] 9.00-10.00 sec 11.0 MBytes 92.4 Mbits/sec 0 220 KBytes
[ 5] 0.00-10.00 sec 111 MBytes 92.9 Mbits/sec 0 sender
[ 5] 0.00-10.00 sec 110 MBytes 92.3 Mbits/sec receiver
Speedtest on host
Retrieving speedtest.net configuration…
Testing from…
Retrieving speedtest.net server list…
Selecting best server based on ping…
Hosted…: 28.825 ms
Testing download speed…
Download: 14.91 Mbit/s
Testing upload speed…
Upload: 52.62 Mbit/s
Speedtest on guest
root@pihole:~# speedtest
Speedtest by Ookla
Idle Latency: 16.24 ms (jitter: 2.05ms, low: 13.47ms, high: 19.51ms)
Download: 18.35 Mbps (data used: 13.4 MB)
22.55 ms (jitter: 31.94ms, low: 5.67ms, high: 262.15ms)
Upload: 52.00 Mbps (data used: 26.8 MB)
16.16 ms (jitter: 11.94ms, low: 7.81ms, high: 172.51ms)
Packet Loss: 0.0%
Speedtest from Router and Switch Stats
