Is it possible to get a list of disks in zpool using without grep/awk/sed?
Hi just came over from the reddit :slight_smile:
I’m trying to find a quick way to get a list of the physical devices in a zpool for use in a script. Is there a way to do this without resorting to grep/awk/sed of zpool status ?
So, instead of this
[root@archlinux ~]# zpool status
  pool: rootfs
        NAME                           STATE     READ WRITE CKSUM
        rootfs                         ONLINE       0     0     0
          mirror-0                     ONLINE       0     0     0
            ata-QEMU_HARDDISK_QM00001  ONLINE       0     0     0
            ata-QEMU_HARDDISK_QM00002  ONLINE       0     0     0
[root@archlinux ~]#
I’d have this
$ some-zpool-command
It’d return all disks for a given pool or all disks for all pools.
Does that exist at all?
In theory—and according to the manpage for zpool get—that would be zpool get physpath rootfs all-vdevs.
The manpage specifies the following syntax for getting properties of vdevs:
zpool get [-Hp ] [-o field[,field]…] all |property[,property]… pool [all-vdevs |vdev]…
And the manpage for vdev properties offers the following relevant properties:
devid
The device id for this vdev
physpath
The physical path to the device
encpath
The enclosure path to the device
edit: But in practice, it turns out that the zpool get all-vdevs feature is only available in OpenZFS master, and hasn’t worked its way down to a proper release yet.
This is the most compact thing I can think of:
zpool list -Pv rpool | awk '/^ / {print $1}'
(that’s 4 spaces at the beginning of line)
You can make a shell function, or a tiny helper command to place in ~/bin if you use this often.
