Is It Worth Using ZVOLs [Performance]
I’ve been setting up a mail server cluster who’s head nodes are doing XFS on DRBD in a three node cluster. The cluster uses Alma10 and has:
  1. Node 1: xfs on drbd on mdraid on 4x SSD
  2. Node 2: xfs on drbd on mdraid on 4x SSD
  3. Node 3: xfs on zvol on 12x 10TB rust (backup node)
There is about 2TB of email, about 3.8 million files. An rsync to one of the head nodes (M1 or M2) takes 15-20 minutes. An rsync to the backup node takes about 2.5 hours.
The major benefit to having the third node is that it can do snapshots and it maintains the data integrity. The head nodes are there for performance.
Thank you for your contribution. During this time, I have been conducting tests in virtual environments, but I haven’t had the time to share my findings.
I’m keeping an eye on it.
One practical distinction: a zvol is a block device, so compare it against a raw file or raw LUN, not qcow2. For a fair test, use a raw image or direct I/O to the zvol, match volblocksize/recordsize to the workload’s I/O size, keep ashift consistent, and test sync versus async writes separately. ZVOLs are still worth using when you need block semantics—ctld/iSCSI, snapshots, or DRBD backing—but I wouldn’t expect datasheet-level throughput from them; those figures likely reflect raw disks or heavily tuned pools, not a full VM stack.
