Hi all,
I was just wondering what the correct type of storage pool to select when creating a VM on a ZFS pool using virt-manager, do you select the type as dir or zfs?
Any help would be greatly appreciated,
Thanks
Hi all,
Thanks
I would recommend using dir. This does mean you’re creating the actual storage on the command line, at least in part:
root@yourbox:~# zfs create zroot/images/newvvm
… which you can then follow up by adding /images/newvm (or however it’s mounted on your filesystem) as a dir type storage pool in virt-manager. You can then add virtual drives in the form of either sparse files or qcow2 files within that dataset.
I’d also recommend a separate dataset for each VM, and typically, for each virtual drive (if you’ve got more than one in the same VM). This allows you to tune them for performance individually, snapshot and roll them back individually, etc.
Fantastic, thank you very much ![]()
Hi again :-),
I was just wondering what the performance implications of using ZFS on the host with EXT4 in the VM vs using ZFS on the host with EXT4 on top of LVM in the VM?
Cheers
Hi!
If you accept my recommendations, I don’t know which OS are you using, but if you are using any Debian like (Ubuntu, etc) you can install libvirt-daemon-driver-storage-zfs package
root@lhome01:~# dpkg -l |grep -i libvirt-daemon-driver-storage-zfs
ii libvirt-daemon-driver-storage-zfs 9.0.0-4 amd64 Virtualization daemon ZFS storage driver
Now you can add to virt-manager storage an entire zfs pool or a simple zfs filesystem (look my PC) where you can create N zvol (not datasets) as you wish/want.
root@lhome01:~# zfs list
zlhome01 2.71T 298G 24K none
zlhome01/HOME 1.97T 298G 24K none
zlhome01/HOME/cmiranda 1.95T 298G 1.13T /home/cmiranda
zlhome01/HOME/root 23.6G 298G 10.2G /root
zlhome01/LIBVIRT 740G 298G 24K none
zlhome01/LIBVIRT/LHOME.bookworm01 9.75G 298G 9.25G -
zlhome01/LIBVIRT/LHOME.data 129G 298G 129G -
zlhome01/LIBVIRT/LHOME.porthos 11.5G 298G 11.5G -
zlhome01/LIBVIRT/ORALAB.centos7a 2.22G 298G 2.14G -
zlhome01/LIBVIRT/ORALAB.esxi7a 729M 298G 729M -
zlhome01/LIBVIRT/ORALAB.ol610a 3.35G 298G 3.30G -
zlhome01/LIBVIRT/ORALAB.ol78a 12K 298G 12K -
zlhome01/LIBVIRT/ORALAB.ol8a 8.28G 298G 5.59G -
zlhome01/LIBVIRT/ORAWORK.mintocs01 19.6G 298G 19.6G -
zlhome01/LIBVIRT/ORAWORK.oud01 216G 298G 194G -
zlhome01/LIBVIRT/ORAWORK.oud02 114G 298G 113G -
zlhome01/LIBVIRT/ORAWORK.w10neo50s 12K 298G 12K -
zlhome01/LIBVIRT/ORAWORK.w10optiplex9020 69.7G 298G 69.7G -
zlhome01/LIBVIRT/ORAWORK.w11h170n 29.2G 298G 29.2G -
zlhome01/LIBVIRT/ORAWORK.w11optiplex9020 128G 298G 84.1G -
zlhome01/LIBVIRT/ol7a 12K 298G 12K -
zlhome01/VAR 13.6G 298G 24K none
zlhome01/VAR/lib.docker 4.16G 298G 4.16G /var/lib/docker
zlhome01/VAR/snap.lxd 9.45G 298G 9.45G /var/snap/lxd/
I suggest creating an individual zvol in the command line with the sparse method with
zfs create -s -V 128G tank/libvirt/VMDISK
And you have 2 ways for tell to virt-manager to use zfs as a storage:
The first method is when you create a new filesystem add to virt-manager using assistant, in my setup my ZFS filesystem is zlhome01/LIBVIRT
Now you can see only zvol in devices list
Look this images:
https://imgur.com/a/PfanVu0
The second method is using virsh pool-add like I post in this tweet:
https://x.com/Mstaaravin/status/1456420002706477067
Why do I use zvol instead qcow2 inside a zfs dataset…?
Because I can use native ZFS snapshots for my VMs and I consider it’s more powerful
@mercenary_sysadmin Any particular reason why you are suggesting qcow2 storage format? It doesn’t make much sense to have yet another Copy on Write storage on top of ZFS?
Also from workload tuning - Virtual Machines openZFS documentation:
Virtual machine images on ZFS should be stored using either zvols or raw files to avoid unnecessary overhead.
If you want to use qemu migration and hibernation tools, you need the qcow2 format.
ZVOLs significantly underperform both raw files and qcow2 files, btw.
This is not a feature I have needed to look into, hence my lack of knowledge. Would you mind sharing any details as to what tooling requires qcow2 format? I can’t see anything in particular in libvirtd that would require qcow2 where raw isn’t possible.
Would you mind sharing resources that supports this statement? I would be interested to know what sort of experimentation was done, if fio was used, what were the profiles.
Thanks in advance.
