Hi everyone,
I have a new machine and I set up an identical zfs pool (same options). I mounted to /mnt (during nixos pre installation).
I then sent a full snapshot of the local machine to the new remote machine over thunderbolt:
on remote:
nc -l "${port}" | sudo zfs receive -vF "${dataset}"
on local:
sudo zfs send -vR "${dataset}@transfer" | nc -v "${ip}" "${port}"
I then made another snapshot on the local host and sent it incrementally:
sudo zfs snapshot -r "${dataset}@now"
sudo zfs send -vI "${dataset}@transfer" "${dataset}@now" | nc -v "${ip}" "${port}"
All commands exited without error, yet if I run
diff \
<(sudo zfs diff "${dataset}@transfer" "${dataset}@now" | LC_ALL=C sort) \
<(ssh "${remote}" sudo zfs diff "${dataset}@transfer" "${dataset}@now" | LC_ALL=C sort)
they differ, where I would have expected the same output.
Is this indicative of erroneous data transfer?
