hi is it possible to go from a raid 1 to raid 10?
i have the following pool:
pool: zroot
NAME STATE READ WRITE CKSUM
zroot ONLINE 0 0 0
nvme1 ONLINE 0 0 0
nvme2 ONLINE 0 0 0
Can i just attach another drive to nvme1 to mirror it and after it resilvered do the same with nvme2 to get a fully redundant striped mirrored pool (raid 10)?
That’s not RAID1 you have there (a mirror vdev), that’s RAID0 (two separate single-disk vdevs). As things stand, you have no redundancy at all.
You can resolve this by zpool attaching a new drive to each of your existing vdevs, turning each one into a mirror vdev (this is the “RAID10” you are asking about, although we don’t really use that terminology in ZFS since it’s not entirely accurate).
root@yourpc:~# zpool attach zroot nvme1 newdisk1
root@yourpc:~# zpool attach zroot nvme2 newdisk2
This is what mirror vdevs look like in zpool status, for future reference:
me@banshee:~$ zpool status
pool: banshee
scan: scrub repaired 0B in 0 days 00:37:41 with 0 errors on Sun May 11 01:01:42 2025
banshee ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
wwn-0x5002538e4982fef1-part5 ONLINE 0 0 0
wwn-0x5002538e4982ff33-part5 ONLINE 0 0 0
Do you see the difference? This is REALLY important, because right now, if I lose one disk, I have no problems–but if you lose one disk, you lose your whole pool.
right my mistake got 0 and 1 mixed up. i know there is no redundancy currently.
thanks for the reassurance i will attach the two new nvme’s as a mirrored vdev so i get a proper mirror.
