I just bought a new computer to run Proxmox VE at home. I installed the Proxmox 8.1-1 ISO. The installation seemed to go smoothly, although I had to use text mode to avoid X windows issues. Unfortunately, the system hangs at “Loading initial ramdisk …”
I have managed to get 7.4 working, but I’d like to be able to move to 8.1.
My system:
- CPU: AMD Ryzen 5600g
- 16 GB RAM
- Video: GEFORCE RTX 4060
- Motherboard: ASRock B550M Pro4
- Microcode: 0xa50000f
Attempts at troubleshooting:
- I edited the GRUB boot line to remove “quiet”. It didn’t say anything useful. “Booting a command list” appeared before the “Loading Linux…” line.
- I ran a memory test. It passed.
- I installed Ubuntu 22.04.3, the server version. It booted up without trouble.
- I installed Debian 12.2.0. It had no issues.
- After I installed Debian, I attempted to install Proxmox on top of it. Once I installed the Proxmox kernel on it, I was back in the same situation.
- I installed Proxmox 7.4. I had to wrestle with X to get the installer to work, but once it was installed it booted up.
So I’m stuck on Proxmox 7.4 until I can figure out some better troubleshooting steps. Any suggestions on what to try next?
(Also posted on Proxmox Support Forum)
