I’m new to the Proxmox system and I’m just learning so please bear with me.
I want to create a VM (my first). When I go to create it in the OS tab I have 3 options
- Use CD/DVD disc image file (iso)
- Use Physical CD/DVD Drive
- Do not use any media
I select Use CD/DVD disc image file. Instead of allowing me to just browse for the file it only allows local storage and then select the image. The host has 2 drives, the OS and a second drive. Only the OS drive is shown for storage.
If I can’t just browse, how can I put the ISO onto the non OS drive so I can select it?
