I’ve got a small home network of a variety of computers (an old 2014-ish macbook with a damaged screen, a 2012 mac mini and a newer lenovo thinkcenter), all have integrated graphics cards.
On initial install using the ISO from Proxmox, rebooting the hosts without a graphics output connected (eg, a monitor, or having the macbook lid open) wasn’t a problem, however, I’ve disabled the subscription repos and the systems have all updated automatically. I’ve discovered that if I now reboot a node, it stops working mid-boot. Also, if I boot with the monitor connected it works right up until I disconnect the monitor.
If I ping a node without a monitor connected, it starts the boot process, I eventually see 5-7 successful pings, and then it stops responding. If I then try again with a monitor connected, it boots successfully, and I can then see the log files, the last few lines are as follows:
Feb 27 21:23:07 pmox1 systemd: Started systemd-journald.service - Journal Service.
Feb 27 21:23:07 pmox1 dmeventd[343]: Monitoring thin pool pve-data-tpool.
Feb 27 21:23:07 pmox1 systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
Feb 27 21:23:07 pmox1 systemd[1]: systemd-firstboot.service - First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
Feb 27 21:23:07 pmox1 systemd[1]: Starting systemd-journal-flush.service - Flush Journal to Persistent Storage...
Feb 27 21:23:07 pmox1 systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
Feb 27 21:23:07 pmox1 systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
Feb 27 21:23:07 pmox1 systemd[1]: Starting systemd-sysusers.service - Create System Users...
Feb 27 21:23:07 pmox1 kernel: EXT4-fs (dm-1): re-mounted 1d5ae3bb-c96f-4691-adfd-06a300eff21a r/w. Quota mode: none.
Feb 27 21:23:07 pmox1 systemd-journald[335]: Time spent on flushing to /var/log/journal/0cf8bbe51c4b418b98d08962082cc50e is 19.290ms for 1047 entries.
-- Reboot --
Feb 27 21:24:11 pmox1 kernel: Linux version 6.5.13-1-pve (build@proxmox) (gcc (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT_DYNAMIC PMX 6.5.13-1 (2024-02-05T13:50Z) ()
Feb 27 21:24:11 pmox1 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-6.5.13-1-pve root=/dev/mapper/pve-root ro quiet
I did try and update the kernel command line by changing /etc/default/grub and using grub-install but that doesn’t seem to have done updated (I added ‘nomodeset’).
Any clues on where to look next to fix this?
Many thanks
