CentOS Stream 8, kernel 4.18.0-513, zfs-2.1.12-1, matching zfs-kmod version.
When booting, the zpool (fs4-pool) is not importing. After a minute we can import the pool from the console, though. Zpool status does not show errors after importing. Could the pool import fail because HDDs are not finished enumerating?
$ dmesg | grep -i zfs
[ 1.266471] systemd[1]: /usr/lib/systemd/system/zfs-snapshot-bootfs.service:8: Unknown lvalue 'ConditionEnvironment' in section 'Unit'
[ 1.269850] systemd[1]: /usr/lib/systemd/system/zfs-rollback-bootfs.service:8: Unknown lvalue 'ConditionEnvironment' in section 'Unit'
[ 1.271896] systemd[1]: /usr/lib/systemd/system/zfs-nonroot-necessities.service:5: Unknown lvalue 'ConditionEnvironment' in section 'Unit'
[ 1.412601] ZFS: Loaded module v2.1.12-1, ZFS pool version 5000, ZFS filesystem version 5
Those first three errors appear to be related to zfs-on-root but that doesn’t apply to me.
These are the more irritating errors:
$ journalctl -b0 | grep -C3 -i zpool
Apr 11 15:52:48 fs4 kernel: XFS (dm-0): Ending clean mount
Apr 11 15:52:48 fs4 systemd[1]: Mounted /sysroot.
Apr 11 15:52:48 fs4 systemd[1]: Starting zfs-nonroot-necessities.service...
Apr 11 15:52:48 fs4 zpool[1501]: cannot import 'fs4-pool': pool was previously in use from another system.
Apr 11 15:52:48 fs4 zpool[1501]: Last accessed by fs4 (hostid=96e572) at Thu Apr 11 22:48:50 2024
Apr 11 15:52:48 fs4 zpool[1501]: The pool can be imported, use 'zpool import -f' to import the pool.
Apr 11 15:52:48 fs4 systemd[1]: zfs-import-scan.service: Main process exited, code=exited, status=1/FAILURE
Apr 11 15:52:48 fs4 systemd[1]: zfs-import-scan.service: Failed with result 'exit-code'.
Apr 11 15:52:48 fs4 systemd[1]: Failed to start Import ZFS pools by device scanning.
Apr 11 15:52:52 fs4 zpool[2367]: cannot import 'fs4-pool': no such pool or dataset
Apr 11 15:52:52 fs4 zed[3044]: eid=2 class=vdev.no_replicas pool='fs4-pool'
Apr 11 15:52:52 fs4 zed[3069]: eid=3 class=vdev.no_replicas pool='fs4-pool'
Apr 11 15:52:52 fs4 zed[3024]: eid=1 class=vdev.no_replicas pool='fs4-pool'
Apr 11 15:52:52 fs4 zed[3098]: eid=5 class=zpool pool='fs4-pool'
Apr 11 15:52:52 fs4 zed[3074]: eid=4 class=vdev.no_replicas pool='fs4-pool'
Apr 11 15:52:52 fs4 zed[3502]: eid=6 class=data pool='fs4-pool' priority=0 err=6 flags=0x8881 bookmark=0:0:-1:0
Apr 11 15:52:52 fs4 zed[3503]: eid=7 class=zpool pool='fs4-pool'
Apr 11 15:52:52 fs4 zed[3556]: eid=8 class=zpool pool='fs4-pool'
Apr 11 15:52:52 fs4 zpool[2367]: cannot import 'fs4-pool': I/O error
Apr 11 15:52:52 fs4 zpool[2367]: Destroy and re-create the pool from
Apr 11 15:52:52 fs4 zpool[2367]: a backup source.
Apr 11 15:52:52 fs4 zpool[2367]: cachefile import failed, retrying
Apr 11 15:52:52 fs4 systemd[1]: zfs-import-cache.service: Main process exited, code=exited, status=1/FAILURE
Apr 11 15:52:52 fs4 systemd[1]: zfs-import-cache.service: Failed with result 'exit-code'.
Apr 11 15:52:52 fs4 systemd[1]: Failed to start Import ZFS pools by cache file.
Apr 11 15:52:52 fs4 systemd[1]: Reached target ZFS pool import target.
Apr 11 15:52:52 fs4 systemd[1]: Reached target ZFS startup target.
Apr 11 15:52:52 fs4 zed[3559]: eid=9 class=zpool pool='fs4-pool'
Apr 11 15:52:52 fs4 systemd[1]: Starting Snapshot ZFS Pool...
Apr 11 15:52:52 fs4 systemd[1]: Starting Virtualization daemon...
Apr 11 15:52:52 fs4 systemd[1]: Starting The Apache HTTP Server...
And the pool:
$ zpool status
pool: fs4-pool
scan: scrub repaired 0B in 07:49:51 with 0 errors on Sat Apr 13 04:52:52 2024
NAME STATE READ WRITE CKSUM
fs4-pool ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
ata-ST4000NM000A-2HZ100_WS209AAM ONLINE 0 0 0
ata-ST4000NM000A-2HZ100_WS22RZX2 ONLINE 0 0 0
ata-ST4000NM000A-2HZ100_WS20CZKS ONLINE 0 0 0
raidz1-1 ONLINE 0 0 0
ata-ST4000NM000A-2HZ100_WS20DB76 ONLINE 0 0 0
ata-ST4000NM000A-2HZ100_WS20DBGB ONLINE 0 0 0
ata-ST4000NM000A-2HZ100_WS20DBHC ONLINE 0 0 0
raidz1-2 ONLINE 0 0 0
ata-ST4000NM000A-2HZ100_WS20DPX1 ONLINE 0 0 0
ata-ST4000NM000A-2HZ100_WS20DQHP ONLINE 0 0 0
ata-ST4000NM000A-2HZ100_WS20DV2P ONLINE 0 0 0
raidz1-3 ONLINE 0 0 0
ata-ST4000NM000A-2HZ100_WS20DVNE ONLINE 0 0 0
ata-ST4000NM000A-2HZ100_WS20DW8Y ONLINE 0 0 0
ata-ST4000NM000A-2HZ100_WS20DWB8 ONLINE 0 0 0
logs
mirror-4 ONLINE 0 0 0
nvme0n1p1 ONLINE 0 0 0
nvme1n1p1 ONLINE 0 0 0
cache
nvme0n1p2 ONLINE 0 0 0
nvme1n1p2 ONLINE 0 0 0
I have created the cache file and it the /etc/hostid file and it matches the dec/hex of the pool.
$ systemctl list-dependencies zfs.target
zfs.target
● ├─zfs-mount.service
● ├─zfs-zed.service
● └─zfs-import.target
● └─zfs-import-cache.service
I don’t understand why cache errors, tho. Is udev-settle not happening?
$ /usr/lib/systemd/systemd --test --debug zfs.target
-> Unit systemd-udev-settle.service:
Description: udev Wait for Complete Device Initialization
Instance: n/a
Unit Load State: loaded
Unit Active State: inactive
State Change Timestamp: n/a
Inactive Exit Timestamp: n/a
Active Enter Timestamp: n/a
Active Exit Timestamp: n/a
Inactive Enter Timestamp: n/a
May GC: no
Need Daemon Reload: no
Transient: no
Perpetual: no
Garbage Collection Mode: inactive
Slice: system.slice
CGroup: n/a
CGroup realized: no
CGroup own mask: memory pids
Documentation: man:udev(7)
Documentation: man:systemd-udevd.service(8)
Fragment Path: /usr/lib/systemd/system/systemd-udev-settle.service
ConditionPathIsReadWrite: /sys untested
Requires: system.slice (origin-file)
Wants: systemd-udevd.service (origin-file)
RequiredBy: zfs-import-scan.service (destination-file)
RequiredBy: zfs-import-cache.service (destination-file)
WantedBy: multipathd.service (destination-file)
Before: sysinit.target (origin-file)
Before: multipathd.service (destination-file)
Before: zfs-mount.service (destination-file)
Before: zfs-import-scan.service (destination-file)
Before: zfs-import-cache.service (destination-file)
After: systemd-udev-trigger.service (origin-file)
After: system.slice (origin-file)
After: systemd-journald.socket (origin-file)
References: systemd-udevd.service (origin-file)
References: systemd-udev-trigger.service (origin-file)
References: sysinit.target (origin-file)
References: system.slice (origin-file)
References: systemd-journald.socket (origin-file)
ReferencedBy: zfs-import-scan.service (destination-file)
ReferencedBy: zfs-import-cache.service (destination-file)
ReferencedBy: multipathd.service (destination-file)
ReferencedBy: zfs-mount.service (destination-file)
Maybe I should enable import zfs-import-scan and zfs-import-cache:
$ systemctl list-unit-files | grep z | grep -v timer | sort
zabbix-agent.service enabled
zed.service enabled
zfs-import-cache.service enabled
zfs-import-scan.service disabled
zfs-import.target enabled
zfs-load-key.service masked
zfs-mount.service enabled
zfs-scrub@.service static
zfs-share.service disabled
zfs.target enabled
zfs-volumes.target disabled
zfs-volume-wait.service disabled
zfs-zed.service enabled
