Question about SAS HBA cards
I was looking into SATA expansion cards like this one.
I’ve seen suggestions online that going with a SAS HBA card would likely be better for multiple reasons. I know with SATA, the 6Gbps is shared between all of the ports. The articles I’ve looked at generally state “SAS offers higher throughout than SATA…”, but I can’t find specifically that if on a 6Gbps SAS card if the throughout is shared, or if every port can use that 6Gbps simultaneously?
I’ve noticed that the SAS cards seem to be at least PCIe 3.0 x4 whereas the majority of SATA cards are x1, even if they have a dozen ports.
This isn’t correct, although it can certainly appear that way, because…
… as you just pointed out, there are multiple potential bottlenecks. In addition to the nominal transfer rate of 6Gbps for SATA-III or 12Gbps for SAS on the front side of the controller, you’ve got a hard bottleneck defined by the number of (hopefully dedicated) PCIe lanes allocated on the back side of the controller interface.
A single PCIe v3 lane is good for a maximum of roughly 2GiB/sec–but that’s the full duplex rate, achieved only by adding full saturation on both the uplink pair and the downlink pair simultaneously. In other words, you can only read up to 1GiB/sec, and you can only write up to 1GiB/sec, but in theory you could do both simultaneously–if the downstream device supported that, that is. (NVMe does. SATA and SAS, for the most part, do not. It’s a bit more complicated than this, and has to do with the available parallelization of storage queues, but that’s pretty much how it works out in the end.)
So, you’ve got a back-end bottleneck of just under 1GiB/sec for a SATA controller, regardless of the number of ports on it… which won’t get you much north of about 750MiB/sec, which looks similar enough to the 6Gbps == ~~750MiB/sec theoretical maximum on a single SATA channel that one might be excused for thinking that the SATA controller is “sharing the 6Gbps across all ports” rather than having a full 6Gbps link between each controller port and its attached device, although being limited by the back end between the controller and the bus, not the front end between controller and devices!
Yep, if you need more than around 750MiB/sec total throughput, and if and only if your SAS controller actually offers more than one PCIe lane.
If you can find a PCIe x1 SATA controller that supports the full throughput of PCIe v5 instead of PCIe v3, you can get a theoretical maximum of 4GiB/sec out of it, just like you can get a theoretical maximum (I’ve seen about 80% of this in real world workloads) of the same 4GiB/sec out of an LSI 9300-8i, which is PCIe v3 x4.
The challenge here is that everything needs to support the higher version of PCIe. Just because you’ve got a PCIev5 motherboard doesn’t mean you get additional PCIe bandwidth out of a PCIe v3 controller plugged into it!
Thank you for the explanation. It makes sense now. I think for my needs, the 6-port version of the card I linked to above should do. I’ve also had my eye on the 9300-8i. Many people say it’ll be more reliable than the ASMedia controller. The SFF cables might be better for cable management as well.
How do you choose what kind of adapter to use? In 2.5 admins, I feel like the recommendation is to avoid onboard SATA ports, but they’re the most likely to be wired to full channel options (clearly board dependent). Do you look for SATA controller cards vs. SAS? I would assume slightly better care and support in an enterprise device vs. a standard SATA card.
Just curious, I don’t want to go get an 8 or 16 port SAS controller, only to bottleneck my system due to lack of PCIe channels.
  1. Proper HBA, not RAID controller
  2. Right kind and number of ports
  3. PCIe bandwidth
Onboard controllers very rarely offer more than a single PCIe lane, while proper HBAs typically start at 4 lanes. PCIe lane bandwidth generally doubles with each generation, which means even if you’ve got a PCIe 5.x board, a PCIe 4.x HBA will most likely still offer at least double the total PCIe bandwidth/throughput that the onboard controller can provide.
One nice thing about the 9500-8i is that it uses much less power (and thus runs cooler) than its predecessors or successors.
I’ve got a shiny new AMD x870e motherboard and after digging have to agree, I’m deeply unclear how much bandwidth the SATA ports have. I got snookered by excellent marketing. It’s not clear that using any PCIe port other than the (usually) graphics card port won’t be fighting for the same resources. It looks like 4 PCIe lanes are shared to the additional controllers.
It looks like a PCIe 3.0 x8 card is ~$100, but the PCIe 4.0 cards are ~$500.
I appreciate the clear guidance.
Which board did you get, and what CPU are you going with? I have a MSI MAG X870E. None of the PCIe expansion slots share bandwidth with anything. The first PCIe slot is full bandwidth with Ryzen 7000/9000 CPUs.
I went with a LSI 9300-8i HBA since I needed more than four ports, but I can’t see myself needing more than eight. Since I don’t need a dedicated GPU, I used the 5.0x16 PCIe slot. I could have used the 4.0x4 slot on my board. The card should negotiate to 3.0x4, which would still be plenty of bandwidth for my needs.
Gigabyte Aorus Pro with a Ryzen 7 9700X. Looks like my three expansion slots ar PCI 5/4 x16 ( or x8 and I suspect by x8 since I’m using the M2 sockets for NVMe), PCI 4.0 x4 and PCI 3.0 x4.
If I reposition my NVMe drives, I might be able to get back to a full PCI 5.0 x16.
I’m in a similar boat, I suspect I’ll have 4 permanent SATA drives, but a bunch as I consolidate data off of a lot of old nearly dead drives. Yay long term projects.
Anyone have thoughts on PCI-e SATA cards or M.2 SATA expanders as alternatives to an HBA?
Documenting for others lost in the PCIe lane math.
This blog/page was helpful in calculating through the marketing of potential lanes, vs available lanes.
I ended up buying an LSI 9211-8i as I don’t expect to run a ton of drives, so this should math out.
I’ll have to switch my name drives to different m2 slots to keep as many lanes free as possible, but I’m hopeful this is helpful. Also definitely had to consult the vendor board diagram to keep the lane consumption math hopefully correct.
