I am now on phase two of shifting my data around and just created a 6 disk Raidz2 out of 1 x 1 TB, 1 x 2 TB, 2 x 3 TB, and 2 x 4 TB drives.
I was expecting to get 3.6 TB pool size, but it comes out 5.45 TB?
That is odd. But you didnât show us any commands and their outputs, so all anybody can say is âthat is odd.â ![]()
I know - sorry
Maybe I should not have done it so late:
To create a similar startpoint I have destroyed the pool zpool destroy fatagnus - I donât know if I should have wiped the disks as well?
zpool create fatagnus raidz2 ata-ST1000DM003-1CH162_S1DGL2PQ ata-ST32000542AS_5XW0L87Q ata-TOSHIBA_HDWD130_Z053RNKAS ata-TOSHIBA_HDWD130_Z053RR2AS ata-WDC_WD40EFZX-68AWUN0_WD-WX22DB1DF7PL ata-WDC_WD40EFZX-68AWUN0_WD-WX52DB1ASC33
invalid vdev specification
use '-f' to override the following errors:
raidz contains devices of different sizes
So I do:
zpool create -f fatagnus raidz2 ata-ST1000DM003-1CH162_S1DGL2PQ ata-ST32000542AS_5XW0L87Q ata-TOSHIBA_HDWD130_Z053RNKAS ata-TOSHIBA_HDWD130_Z053RR2AS ata-WDC_WD40EFZX-68AWUN0_WD-WX22DB1DF7PL ata-WDC_WD40EFZX-68AWUN0_WD-WX52DB1ASC33
zpool status fatagnus
pool: fatagnus
NAME STATE READ WRITE CKSUM
fatagnus ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
ata-ST1000DM003-1CH162_S1DGL2PQ ONLINE 0 0 0
ata-ST32000542AS_5XW0L87Q ONLINE 0 0 0
ata-TOSHIBA_HDWD130_Z053RNKAS ONLINE 0 0 0
ata-TOSHIBA_HDWD130_Z053RR2AS ONLINE 0 0 0
ata-WDC_WD40EFZX-68AWUN0_WD-WX22DB1DF7PL ONLINE 0 0 0
ata-WDC_WD40EFZX-68AWUN0_WD-WX52DB1ASC33 ONLINE 0 0 0
zpool list fatagnus
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
fatagnus 5.45T 1.23M 5.45T - - 0% 0% 1.00x ONLINE -
And version:
zpool version
zfs-2.2.6-pve1
zfs-kmod-2.2.6-pve1
Have I by doing -f accepted an odd way of distributing data and parity?
zpool list shows you RAW capacity, not capacity after redundancy/parity. So, roughly 6T for six roughly 1T disks.
Either zfs list or df will show you the correct capacity estimate.
As is often the case, Jim You are right ![]()
zfs list fatagnus
fatagnus 839K 3.52T 192K /fatagnus
Time to start throwing the datasets back onto fatagnus.
In case anybody is wondering âWhy is he wasting 2 x 4TB and 2 x 3 TB drives mixing them with a 2 TB and even a 1 TB drive?â - the answer is that this is temporary. Tank is a 4 TB and an 8 TB drive and those two are going to replace the 1 TB and 2 TB drives, as soon as I have shifted the datasets.
When the 1 TB and 2 TB drives are out of the RaidZ2 pool, I will remove them from the box and replace them with two smallâish SSDs - 480 GB + 500 GB - and create a mirror for container and VM storage. I will have to split my Nextcloud LXD container storage between the OS and application on the SSD storage and then put the data on the spinning pool. Probably through a mount point in Proxmox.
I will be monitoring the performance of the 4 TB from Tank as it is a 2.5" hdd and thus most likely is an SMR drive - I might be replacing that before the two smaller 3 TB drives.
