Removing Additional Mirror Disks Added to Existing Mirror Vdev
Hello All,
I have a mirror zpool tank to which I added an additional pair of mirrored disks to an existing vdev instead of adding an additional mirror vdev to the pool.
Is there a way to remove the two disks incorrectly added or will this require a rebuild of the pool?
       NAME             STATE       READ WRITE CKSUM
        tank             ONLINE       0     0     0
          mirror-0       ONLINE       0     0     0
            Drive1       ONLINE       0     0     0
            Drive2       ONLINE       0     0     0
          mirror-1       ONLINE       0     0     0
            Drive1       ONLINE       0     0     0
            Drive2       ONLINE       0     0     0
            Drive3       ONLINE       0     0     0
            Drive4       ONLINE       0     0     0
In this case, I would like to remove Drive3 and Drive4
Take a look at man 8 zpool-detach.
Ok thanks, I’ll try it on a VM
Luckily with mirrors, this is simple.
As pointed out:
zpool detach tank drive5
zpool detach tank drive6
pro tip: when you are trying to add the new disks, first run the command with the -n flag (noop), and it will show you what the config will look like, but not actually change anything. This helps confirm it does what you want before you run it:
zpool add -n tank mirror drive5 drive6
        tank
          mirror-0
            Drive1
            Drive2
          mirror-1
            Drive3
            Drive4
          mirror-2
            Drive5
            Drive6
If you are happy, then remove the -n and it will do it for real.
Thanks for all of the tips everyone. I really appreciate it.
I was able to resolve the issue with the help of the following document.
https://docs.oracle.com/cd/E19253-01/819-5461/gcfhe/index.html
Thanks again for all of the help!!
