i have the following pool where i want to replace nvme-eui.2 and nvme-eui.4
NAME STATE READ WRITE CKSUM
zroot ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
nvme-eui.1-part2 ONLINE 0 0 0
nvme-eui.2-part2 ONLINE 0 0 0
mirror-1 ONLINE 0 0 0
nvme-eui.3-part2 ONLINE 0 0 0
nvme-eui.4-part2 ONLINE 0 0 0
can i just disconnect them, put two new nvme drives in and let them resilver? or should i do zfs detaching before?
It’s a bit nicer to detach them first, but not technically necessary.
You should scrub first, though.
there won’t be any issue with removing these drives with detach while its running right? i ask since its my OS drive
ankek
6
Hi, there are 3 ways: safe, unsafe, very unsafe.
Safe is:
- Create backup of data.
- Destroy pool.
- Replace nvme disks.
- Build new pool.
Unsafe is (Simulate a disk failure and rebuild the Zpool):
Works if you have an empty slot for nvme (5 nvme disks in total)
- Add 5-th disk in system
- zpool status test-pool
- zpool replace test-pool /nvme-eui.2 /nvme-eui.5 (please specify mirror and other options that you used during pool creation)
- zpool scrub test-pool
- zfs list
Very unsafe is (Simulate a disk failure and rebuild the Zpool):
Very dangerous way because of data loss option
- Turn off system.
- Replace disk 2 by disk 5 in system.
- Power up system.
- zfs list
- Repeat from step 2 for nvme-eui.4 .
