Rigid pool sizes?
It looks like it’s important to get your vdev and pool sizes correct up front. It looks hard to muck about with those after the fact.
Is that a fair assumption?
IMO only partly true.
It is definitely easier / better to have a pool layout and stick with it, but there is a reasonable amount of flexibility if you need it i.e. you can add and remove mirrors or vDevs from an all-mirror pool, and you can add a drive to a RAIDZ vDev to expand the space. But there are some minor consequences and / or follow-up actions that you might need to do.
Could you please elaborate on this, thank you.
I am not a true expert here but a few examples that I understand to be the case (but I may be wrong):
  • When resilvering you should try to add a drive to your hardware, resilver and then remove the old drive because that retains more redundancy during the resilver.
  • When you remove a mirror vDev, blocks are mapped rather than moved - and the mapping takes some resources.
  • When you add a new mirror or RAIDZ vDev, it remains empty and you need to run zfs rewrite to rebalance the pool.
  • When you expand a RAIDZ vDev, although data is moved around to spread it evenly across the new number of drives, the for existing data the old data:parity ratio is retained and you need to run zfs rewrite to make the data:parity match the new layout (and recover some space).
Since OpenZFS 2.3 you’ve been able to expand a vdev by adding drives. What you can’t change though is the vdev’s parity level. So if you have a raidz1 vdev, you can’t increase the parity to raidz2 by adding drives or by any other means. So that’s an important thing to decide when creating a vdev.
You can also expand a pool’s capacity by adding more vdevs later on. Eventually a vdev becomes “too large” in terms of number of disks. There have been many discussions around when that point is.
