Samba Performance for MacOS Clients (TrueNAS Scale)
A less-technical friend of mine was looking for a NAS, so I pointed him at the TrueNAS mini and told him I would help him set it up. Set up went swell (we set up TrueNAS scale because he needed to have access to his music by SMB and over Plex, and I don’t know how to do that in Core), but he uses MacOS and we found that due to Apple “Thinking Different” about how standard protocols should work, SMB share operations are abysmally slow. It was about 10MB/s maximum over a wired connection. My linux laptop could do nearly 100MB/s over wifi.
Some searching led me to find this is apparently a known issue and that Samba has a “fruity mode” that should fix this, but I have yet been unsucessful in enabling that mode or making any other changes on his client or the server to increases speeds.
We tried using NFS, but that process is not user-friendly at all on MacOS. He dropped 2 grand to have a good NAS experience and so far this isn’t it. Does anyone have any experience making SMB tolerable for Mac Clients using TrueNAS Scale?
As you e probably seen, this is a pretty well documented problem. We use Macs at my office and this is my least favorite part of the experience.
Here are the recommendations from the Samba wiki, which I think are helpful.
There are also client-side things that can help, like disabling writing .DS_Store files to the shares. Check this out.
If you can bear it, make changes one by one and test that way you’ll know what is actually making a difference.
Thank you so much. I’ll check out these recommendations and see if I can make some headway. I found reference to the fruity mode, but couldn’t find anything this specific, so I appreciate it.
Not that this is an acceptable excuse, but I spent many years administering airgapped datacenters, and have found that my google-fu has suffered greatly.
I maintain Samba servers for a broad mix of computer clients and, while I agree that Samba on the macOS side isn’t as easy as it can be on other OSes, it is possible to get highly performant access to that data.
In my smb.conf file, as part of the [Global] section, I include some tweaks alleged to make macOS performance better:
fruit:aapl = yes
fruit:model = MacSamba
vfs objects = catia fruit streams_xattr
fruit:nfs_aces = no
fruit:zero_file_id = yes
fruit:metadata = stream
fruit:encoding = native
And, in the definitions for each share I also include:
veto files = /._*/.DS_Store/
delete veto files = yes
(This are more for my sanity than anything else…)
I can confirm that none of these changes negatively impacted performance on Windows and Linux clients. And, I can likewise confirm that these changes did improve my SMB access from 40MB/s to closer to 65MB/s.
Recently though I made a change to my primary Mac workstation that has me rethinking my testing. All of my testing had been done via a wired connection to my M1 Pro Macbook Pro via a CalDigit ‘USB-C Pro’ dock (which is actually a Thunderbolt 3 dock, and connected to my Mac via Thunderbolt). This is the machine I saw the 33% speed bump.
I have, for unrelated reasons, upgraded my home network to 2.5Gb and bought a cheap USB-C 2.5Gb adapter, which I’ve since connected to the dock and have stopped using the network jack built into the dock.
I expected this not to impact Samba share performance, and made no attempt to even test, but in my normal activities I was transferring some files from the Samba server (Debian 12 with a ZFS ‘RAID10’ of striped mirrors) and saw reliable performance around 110Mb/s. Essentially, saturating the gigabit connection from the server.
I may find the time to do some further testing - I’m curious to know if this network adapter would perform this well when connected at gigabit speed too. I’m also wondering if my speed limits were more a function of the dock, and if I’d see similar performance with other USB connected NICs.
Just my two cents…
Interesting. I can saturate a 2x10 Gbe SMB MultiChannel connection between my Macs (2018 Mini and 2022 M1 Studio) and an NVMe pool on my NAS (Ugreen 6800 Pro running 24.10 when copying large files over SMB. That’s using the on-board 10gbe ports on the Macs plus a TB4 10Gbe adapter. No SMB tuning done at all.
Maybe macOS is overly chatty and that goes away with fast connections?
Thanks for the links and suggested configs. I’m going to have to take a closer look at these.
Lately, I’ve been trying to track down why Samba Server Side Copy isn’t enabled by default in TrueNAS for Mac clients (a fruit flag is required in the config, which is missing from TrueNAS’s smb4.conf and can’t easily be set in the GUI or in a way tha survives reboot, not without a post-boot script that makes some API calls to manually enable the thing).
It turns out that due to the way Apple implements SMB, using Server Side Copy from a Mac client potentially risks unstable SMB transfers happening for … reasons that are off-topic, but that’s a whole other rabbit-hole. Here’s a Samba dev explaining why you probably want to leave SSC for Macs disabled: [Samba] Documentation/Feature Clarification Request: Server Side Copy and VFS_FRUIT
There are two styles of SSC:
  • the “normal” protocol style called copy-chunk, where the copy is
    requested in IO ranges by the client and performed server-side
  • the Apple way enabled by fruit:copyfile where the client requests the
    whole file to be copied in one request to be performed by the server
The problem with the latter is that for large file the copy takes some
time and meanwhile the client is blocked waiting for IO to complete. If
the copy takes longer then the SMB request timeout time (iirc default
30s) the requests times out and the client will disconnect the connection.
My recommendation is to stay away from fruit:copyfile for these reasons.
But the thing I wanted to mention was that during the whole process of trying to understand why TrueNAS was configured the way it is, I learned from one of the devs’ comments on their forums that they don’t have automated SMB protocol testing for Mac or Windows clients to the same degree that they do for Linux clients: SMB (Samba) Server-Side Copy Support: Enabled for Mac OS? - #38 by Captain_Morgan - TrueNAS General - TrueNAS Community Forums
Its a great example of where Community testing is needed.
WE can automate testing of linux clients using standard protocols.
When it comes to the matrix of testing each client OS and each feature… its not automated. We rely on the Community to test and report.
We do have basic testing of Windows and Macs… but not feature-level testing and OS version testing. That matrix is enormous and changes for every update they do.
So, from that, I think it’s reasonable to assume that TrueNAS’ defaults aren’t optimized for Mac use, and we’re own our own and assuming all the risk if we try to change them. Not that we shouldn’t be able to do that, but I think it’se reasonable to expect that iX might not be able to help if something goes wrong.
I think this is exactly it. Aside from potential optimization issues, modern macOS versions largely assume fast random storage IO; that is, they essentially assume storage IO is happening with SSDs rather than hard drives (this is evident in the way APFS stores metadata, for example; it scatters the metadata across the disk rather than more contiguously [source]). macOS is likely poorly optimized for HDD-based IO, even over a network (NAS).
APFS (the default file system for modern MacOS) is optimized for performance and minimal wear on SSDs. It’s been known since at least 2017 that the cost for this is poor performance on spinning rust HDDs.
I’m sure that has implications for reading and writing to HDD-based Samba shares, but Apple’s SMB client implementation itself (SMBX) is also known to be less well-optimized and featureful than a Samba (Linux) or native Windows client.
This isn’t going to really make an impact, if APFS is being run in a VM on top of ZFS storage (or on ZFS storage via iSCSI), because ZFS will nod its head sagely at the “location” APFS asks to put sectors/clusters, and go right the hell about writing them wherever ZFS would normally write them anyway, since ZFS is essentially presenting the APFS filesystem with a fake, virtual block address map that ZFS itself translates down to the actual physical sectors of the drives in question.
With that said, if you’re using zvols, you’re going to lose a LOT of performance right there. Zvol performance sucks, a lot. You’re generally much better off using a sparse file (eg truncate -s 100G hundredgig.raw) rather than a zvol.
Make sure to set recordsize (or, if you insist on using zvols, god help you, volblocksize) appropriately to your workload–set it too low, you amplify IOPS demands of a relatively easy workload that otherwise could get more throughput; set it too high, you wind up with read/write amplification that will cripple more difficult, high-IOPS workloads.
Update: Server-Side Copy should work correctly for MacOS SMB clients in TrueNAS 25.04.2 without needing to set the VFS_FRUIT flag that’s so potentially problematic that it is disabled by default by the Samba devs.
I originally filed a feature request for TrueNAS to enable the VFS_FRUIT-based feature, before I understood that enabling SSC for Mac clients via VFS_FRUIT would potentially destabilize server-side copy operations initiated from Mac clients.
See: [Accepted] Enable Mac SMB (Samba) Server-Side Copy Support by Default or Provide a Toggle in SMB Service Advanced Options - Feature Requests - TrueNAS Community Forums
Eventually, I went to get some more information from the Samba devs about what the potential issue is: https://lists.samba.org/archive/samba/2025-May/251551.html
So, in that context, Samba’s default behavior of disabling SSC for Mac clients makes good sense. Exchanging data consistency for speed isn’t a great idea.
Bringing that to the attention of the TrueNAS devs led to a dev exploring exactly what the Mac OS SMB client does and potential ways to get around it without invoking the problematic VFS_FRUIT feature. [Accepted] Enable Mac SMB (Samba) Server-Side Copy Support by Default or Provide a Toggle in SMB Service Advanced Options - #16 by awalkerix - Feature Requests - TrueNAS Community Forums
The patch to TrueNAS’ internal Samba fork to fix SSC for Mac OS clients without invoking VFS_FRUIT (and its potential stability issues as discussed in the Feature Request thread) has been completed and will appear in TrueNAS 25.04.2 in July 2025: Jira
So that’s on the way. :slight_smile:
The same iX dev is working on getting that change (or something equivalent) pushed upstream to Samba itself.
This immediately raised my eyebrows. I’ve had a Samba configuration I’ve been pulling along since 2005 or so. I recently upgraded to 2.5GBe on my LAN, and my MacBook can easily max the network connection out at around 180MB / sec. This is with large files, and performance is certainly worse with many small files.
The Samba config started with Gentoo (!), then moved to Ubuntu, and now is in an Alpine container under Proxmox. The source drives are regular spinning rust in ZFS “RAID10” style pools. On Wifi I get 40-60MB/sec, and that’s with older UniFi APs that I’m sure are the bottleneck.
I don’t have any client-side changes made. I do have vfs_fruit enabled, but I’m not sure anything would affect performance. It was mostly for Time Machine and metadata support.
I could totally see the various fruit:* options affecting performance with many small files, but not with large ones where the metadata is so small compared to the data transferred.
Improving the performance of Time Machine backups to network storage – The Eclectic Light Company Has some pretty great details on SMB performance with many small files which I imagine still hold up in modern macOS release.
Hallo, I was also struggling with MacOS performance, this smb.conf works perfectly:
MACOS optimizations
min protocol = SMB2
Apple optimizations
fruit:aapl = yes
fruit:resource = stream
fruit:model = Macintosh
fruit:posix_rename = yes
fruit:veto_appledouble = no
fruit:nfs_aces = no
fruit:wipe_intentionally_left_blank_rfork = yes
fruit:delete_empty_adfiles = yes
Catch macOS-specific problems (e.g. .DS_Store on shares).
ea support = yes
spotlight = no
inherit acls = yes
Performance
strict locking = no
kernel oplocks = no
oplocks = yes
aio read size = 64k
aio write size = 64k
Just my input on the matter…
I am managing a few large ZFS based Ubuntu servers and a bunch of MacOS users, and I have experimented a bit…
We have also tewaked the smb.conf stuff mentioned, but mainly to “fix” the issue with the “.DS_Store” creation.
We can easyly write/read with 100MB/sec. from a Mac, that’s not the problem…
The problem is that MacOS wants to read metadata from the files in a folder, so if you have many files in a folder, especially media/images etc. it will take awhile to show you the contens.
This behaviour seems to be burried deep insite MacOS.. because not even exporting the data via NFS will solve this… and not even switching from “Finder” to “Path Finder” will fix this…
The only way I know of, is using Midnight Commander in the command line… :slight_smile:
I guess that mc does not need to read any metadata, and is able to browse fodlers with large ammount of files with ease…
To my knowledge noone have created anything that works like mc as an graphical app…?
Can confirm that these config parameters made a DRAMATIC difference at a Mac centric client that I recently upgraded from OpenMediaVault (which didn’t provide easy access to directly modify smb.conf) to XigmaNAS (which makes it so stupid easy, you don’t even have to leave the GUI).
This is an engineering firm with insane numbers of images in some folders, and it went from “some folders will be unusable for upwards of a minute while thumbnails render” to “looks just like a local folder on a fast system.”
I just want to share my 2 cents.
I have a debian server on ZFS serving directories via samba to a macmini. The performance is good, around 90 MB/s
The smb.conf has the following mac specific settings:
[global]
#https://www.thedigitalpictureframe.com/installing-samba-on-your-raspberry-pi-buster-and-optimizing-it-for-macos-computers/
client min protocol = SMB2
client max protocol = SMB3
# fruit:model = RackMac
These are the default values if not set, so you don’t have to specify them.
Wouldn’t most zfs hosts use xattr for this?
I suspect the next three items are the ones that improve performance. However, I’m not seeing any difference loading directories with a few hundred items - they still take my Mac several seconds to load.
The man page says:
The only reasonable values for this parameter are 0 (no async I/O) and 1 (always do async I/O).
It doesn’t say that k is valid, so I’m not sure if it’s treating this as 64k or 64 bytes.
