Sharing a ZFS filesystem to two or more KVM virtual machines (running IMAP+webmail apps)
Hi all,
I’m planning to set up a new Linux server for hosting lots of e-mail (very many accounts) and related applications (Exim, Dovecot, Apache, PHP-FPM, Roundcube…). I’ve used Adaptec controller + LVM thinpools for years, but this time, I’d like to make the server more resilient against outages by using an LSI HBA + ZFS (on RAID1 mirrors) instead. Mainly I want to rule out lengthy XFS filesystem checks and quota checks on multi-TB arrays after a crash, during which the system services can’t function properly, and also to take advantage of ZFS features like frequent snapshots, quick block-level updates for backups, and quick periodic updates of all data on a replica server, which will be ready to take over if needed. Also, I’d like to use something (ZFS) more admin-friendly than LVM.
Disks, ZFS filesystems with user quotas, and the user accounts will be set up on the host, which will function as a storage backend for several applications. But I want those applications to run in VMs hosted on the same box (for performance and for not wanting to pay for additional physical boxes), so I need the ZFS files to be equally well accessible in two Linux VMs (KVM, qemu) running on the same host - a production VM, and a test/dev VM.
(I want to run the applications in VMs, not on the host, so that I can work on new versions of the applications and test them in a dev VM, while the production VM is available to users at the same time. Why? There’s no testing like on a production server, with the real data. After the new set of apps is ready, I can just switch them to production role.)
There are several ways to achieve sharing of the host ZFS filesystem into a VM virtual filesystem, but from past experience with KVM+qemu and some rudimentary stuff I remember reading on this, I expect them to have quite diverse performance, reliability and gotchas in nonstandard situations.
I know of these methods of fs sharing to a VM:
  • NFS (never deployed it, but I worry about bad performance with sync operations, and problems with unmounting the filesystem in the VM);
  • SSHFS (easy to set up, but based on experience, I expect severely degraded performance in the VM);
  • 9P folder sharing (don’t know much about it, expecting mediocre/bad performance, worry about maturity and future of this tech - Redhat/IBM does not seem to have much interest in desktop and KVM these days).
I’m not sure how these options fare with quotas in VM though.
What I really need in the VM is quotas.
The ideal (not sure if it exists) way would be to share the ZFS filesystem in such a way so that in the VM, it is seen as the same ZFS filesystem as well, manageable with zfs and zpool commands.
What do you think is the best option for the task? The most important things are reliability+quotas in the VM, and then performance. The least important is being easy to setup and nice to use; I can manage with bad UX and gotchas.
If a performant solution exists only for sharing ZFS into containers, but not into VMs, I might try containers instead (e.g. via Incus).
I’d appreciate any comments/advice you may have.
I don’t have experience with all of these, but I’d expect NFS to be plenty performant for an e-mail server, especially served from the host to a VM. You can disable sync writes for better write performance if that’s important to you. Also, if you’re concerned about unmounting and re-mounting, look into autofs. It’s pretty easy to set up (not quite as simple as fstab) and it will automatically mount an export when when its resources are requested.
Thank you. Yeah, NFS is starting to look as the way to go - it’s here for a long time, not going anywhere, seems to do everything I need it to.
Any experience on how well ZFS + NFS work together?
Do you know of a good detailed resource on how to set up ZFS(host)-NFS-ZFS(VM), so that I can have the same usernames and userids, with same quotas, in both the host and the VM?
They work just fine together. Make sure you’ve got a LOG vdev if you’re using sync NFS (which is the default), and ESPECIALLY if you’re using rust for your main storage vdevs.
You don’t really need to set the quotas in both places; set them on the host and they’ll apply equally to the host and any guests you share the enquota’d datasets with.
For matching UIDs, there’s not really any special trick I know of. Just create matching usernames with preferably matching UIDs. (I think you can set up a translation table if your UIDs don’t match, but if you’re setting this up from scratch, easier and cleaner to just make them match in the first place.)
If you didn’t already know, btw, you can manually specify the UID for new user accounts as you create them, using the -u argument. So, eg, useradd -u 999 bob -g 999 if you want to create a user named bob with UID and GID both set to 999.
