Suddenly poor write speeds because simultaneous lots of reads take place
Hi,
Thanks for reading my question!
I have setup the pool this week and its been in full use for couple of days now.
It was performing fine with the speed you could expect from the underlying harddisks
But today I noticed the write speed of the pool got real bad without understanding the reason.
When i do zpool iostat -n 1 is see more reads than write when copying data to the zfs volume
                       capacity     operations     bandwidth
pool                     alloc   free   read  write   read  write
vm_server_storage_raidz  8.00T  2.91T    278    126   174M  85.5M
vm_server_storage_raidz  8.00T  2.91T    291     84   184M  56.9M
vm_server_storage_raidz  8.00T  2.91T    298     86   188M  53.4M
vm_server_storage_raidz  8.00T  2.91T    328     78   210M  51.4M
vm_server_storage_raidz  8.00T  2.91T    352     97   234M  70.9M
vm_server_storage_raidz  8.00T  2.91T    242    153   145M   101M
vm_server_storage_raidz  8.00T  2.91T    256    111   145M  67.9M
vm_server_storage_raidz  8.00T  2.91T    269    104   170M  66.4M
The pool consists of 3x toshiba 4tb sas disks (2019 512n) in raidz1.
Blocksize is 1m because its 99% used for big media files.
Changes to zfs pool I made are,
logbias=throughput (did it for performance but was using the wrong blocksize for my usage after all)
sync=disabled (also for performance, everything is always in 2 places and have backups)
I’m using zfs (v2.1.12-pve1) in proxmox (8.0.4 fully up to date)
root@pve:~# zpool list
NAME                         SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP    HEALTH  ALTROOT
bedrijf_share_480gb_mirror   444G   174G   270G        -         -     0%    39%  1.00x    ONLINE  -
vm_server_storage_raidz     10.9T  8.00T  2.91T        -         -     0%    73%  1.00x    ONLINE  -
root@pve:~# zpool status
pool: vm_server_storage_raidz
scan: scrub repaired 0B in 08:00:14 with 0 errors on Sun Aug 13 08:24:16 2023
    NAME                        STATE     READ WRITE CKSUM
    vm_server_storage_raidz     ONLINE       0     0     0
      raidz1-0                  ONLINE       0     0     0
        scsi-350000399b8298ff5  ONLINE       0     0     0
        scsi-350000399b8297c35  ONLINE       0     0     0
        scsi-350000399a832a841  ONLINE       0     0     0
root@pve:~# zfs get all vm_server_storage_raidz
NAME                     PROPERTY              VALUE                     SOURCE
vm_server_storage_raidz  type                  filesystem                -
vm_server_storage_raidz  creation              Fri Aug 11 16:49 2023     -
vm_server_storage_raidz  used                  7.14T                     -
vm_server_storage_raidz  available             264M                      -
vm_server_storage_raidz  referenced            128K                      -
vm_server_storage_raidz  compressratio         1.01x                     -
vm_server_storage_raidz  mounted               yes                       -
vm_server_storage_raidz  quota                 none                      default
vm_server_storage_raidz  reservation           none                      default
vm_server_storage_raidz  recordsize            128K                      default
vm_server_storage_raidz  mountpoint            /vm_server_storage_raidz  default
vm_server_storage_raidz  sharenfs              off                       default
vm_server_storage_raidz  checksum              on                        default
vm_server_storage_raidz  compression           on                        local
vm_server_storage_raidz  atime                 off                       local
vm_server_storage_raidz  devices               on                        default
vm_server_storage_raidz  exec                  on                        default
vm_server_storage_raidz  setuid                on                        default
vm_server_storage_raidz  readonly              off                       default
vm_server_storage_raidz  zoned                 off                       default
vm_server_storage_raidz  snapdir               hidden                    default
vm_server_storage_raidz  aclmode               discard                   default
vm_server_storage_raidz  aclinherit            restricted                default
vm_server_storage_raidz  createtxg             1                         -
vm_server_storage_raidz  canmount              on                        default
vm_server_storage_raidz  xattr                 on                        default
vm_server_storage_raidz  copies                1                         default
vm_server_storage_raidz  version               5                         -
vm_server_storage_raidz  utf8only              off                       -
vm_server_storage_raidz  normalization         none                      -
vm_server_storage_raidz  casesensitivity       sensitive                 -
vm_server_storage_raidz  vscan                 off                       default
vm_server_storage_raidz  nbmand                off                       default
vm_server_storage_raidz  sharesmb              off                       default
vm_server_storage_raidz  refquota              none                      default
vm_server_storage_raidz  refreservation        none                      default
vm_server_storage_raidz  guid                  8487269358916759388       -
vm_server_storage_raidz  primarycache          all                       default
vm_server_storage_raidz  secondarycache        all                       default
vm_server_storage_raidz  usedbysnapshots       0B                        -
vm_server_storage_raidz  usedbydataset         128K                      -
vm_server_storage_raidz  usedbychildren        7.14T                     -
vm_server_storage_raidz  usedbyrefreservation  0B                        -
vm_server_storage_raidz  logbias               throughput                local
vm_server_storage_raidz  objsetid              54                        -
vm_server_storage_raidz  dedup                 off                       default
vm_server_storage_raidz  mlslabel              none                      default
vm_server_storage_raidz  sync                  disabled                  local
vm_server_storage_raidz  dnodesize             legacy                    default
vm_server_storage_raidz  refcompressratio      1.00x                     -
vm_server_storage_raidz  written               128K                      -
vm_server_storage_raidz  logicalused           5.41T                     -
vm_server_storage_raidz  logicalreferenced     42K                       -
vm_server_storage_raidz  volmode               default                   default
vm_server_storage_raidz  filesystem_limit      none                      default
vm_server_storage_raidz  snapshot_limit        none                      default
vm_server_storage_raidz  filesystem_count      none                      default
vm_server_storage_raidz  snapshot_count        none                      default
vm_server_storage_raidz  snapdev               hidden                    default
vm_server_storage_raidz  acltype               off                       default
vm_server_storage_raidz  context               none                      default
vm_server_storage_raidz  fscontext             none                      default
vm_server_storage_raidz  defcontext            none                      default
vm_server_storage_raidz  rootcontext           none                      default
vm_server_storage_raidz  relatime              off                       default
vm_server_storage_raidz  redundant_metadata    all                       default
vm_server_storage_raidz  overlay               on                        default
vm_server_storage_raidz  encryption            off                       default
vm_server_storage_raidz  keylocation           none                      default
vm_server_storage_raidz  keyformat             none                      default
vm_server_storage_raidz  pbkdf2iters           0                         default
vm_server_storage_raidz  special_small_blocks  0                         default
root@pve:~# zpool get all vm_server_storage_raidz
vm_server_storage_raidz  size                           10.9T                          -
vm_server_storage_raidz  capacity                       73%                            -
vm_server_storage_raidz  altroot                        -                              default
vm_server_storage_raidz  health                         ONLINE                         -
vm_server_storage_raidz  guid                           7167498555092595164            -
vm_server_storage_raidz  version                        -                              default
vm_server_storage_raidz  bootfs                         -                              default
vm_server_storage_raidz  delegation                     on                             default
vm_server_storage_raidz  autoreplace                    off                            default
vm_server_storage_raidz  cachefile                      -                              default
vm_server_storage_raidz  failmode                       wait                           default
vm_server_storage_raidz  listsnapshots                  off                            default
vm_server_storage_raidz  autoexpand                     off                            default
vm_server_storage_raidz  dedupratio                     1.00x                          -
vm_server_storage_raidz  free                           2.91T                          -
vm_server_storage_raidz  allocated                      8.00T                          -
vm_server_storage_raidz  readonly                       off                            -
vm_server_storage_raidz  ashift                         12                             local
vm_server_storage_raidz  comment                        -                              default
vm_server_storage_raidz  expandsize                     -                              -
vm_server_storage_raidz  freeing                        0                              -
vm_server_storage_raidz  fragmentation                  0%                             -
vm_server_storage_raidz  leaked                         0                              -
vm_server_storage_raidz  multihost                      off                            default
vm_server_storage_raidz  checkpoint                     -                              -
vm_server_storage_raidz  load_guid                      14822383124988917419           -
vm_server_storage_raidz  autotrim                       off                            default
vm_server_storage_raidz  compatibility                  off                            default
vm_server_storage_raidz  feature@async_destroy          enabled                        local
vm_server_storage_raidz  feature@empty_bpobj            active                         local
vm_server_storage_raidz  feature@lz4_compress           active                         local
vm_server_storage_raidz  feature@multi_vdev_crash_dump  enabled                        local
vm_server_storage_raidz  feature@spacemap_histogram     active                         local
vm_server_storage_raidz  feature@enabled_txg            active                         local
vm_server_storage_raidz  feature@hole_birth             active                         local
vm_server_storage_raidz  feature@extensible_dataset     active                         local
vm_server_storage_raidz  feature@embedded_data          active                         local
vm_server_storage_raidz  feature@bookmarks              enabled                        local
vm_server_storage_raidz  feature@filesystem_limits      enabled                        local
vm_server_storage_raidz  feature@large_blocks           active                         local
vm_server_storage_raidz  feature@large_dnode            enabled                        local
vm_server_storage_raidz  feature@sha512                 enabled                        local
vm_server_storage_raidz  feature@skein                  enabled                        local
vm_server_storage_raidz  feature@edonr                  enabled                        local
vm_server_storage_raidz  feature@userobj_accounting     active                         local
vm_server_storage_raidz  feature@encryption             enabled                        local
vm_server_storage_raidz  feature@project_quota          active                         local
vm_server_storage_raidz  feature@device_removal         enabled                        local
vm_server_storage_raidz  feature@obsolete_counts        enabled                        local
vm_server_storage_raidz  feature@zpool_checkpoint       enabled                        local
vm_server_storage_raidz  feature@spacemap_v2            active                         local
vm_server_storage_raidz  feature@allocation_classes     enabled                        local
vm_server_storage_raidz  feature@resilver_defer         enabled                        local
vm_server_storage_raidz  feature@bookmark_v2            enabled                        local
vm_server_storage_raidz  feature@redaction_bookmarks    enabled                        local
vm_server_storage_raidz  feature@redacted_datasets      enabled                        local
vm_server_storage_raidz  feature@bookmark_written       enabled                        local
vm_server_storage_raidz  feature@log_spacemap           active                         local
vm_server_storage_raidz  feature@livelist               enabled                        local
vm_server_storage_raidz  feature@device_rebuild         enabled                        local
vm_server_storage_raidz  feature@zstd_compress          enabled                        local
vm_server_storage_raidz  feature@draid                  enabled                        local
System is a hp ml150 g9 xeon 2650 v4/128gb
So the pool name is vm_server_storage_raidz, but you are saying that it is 99% used for big media files? Are you running VM(s) on top of this storage?
I’m not running VM’s on top of ZFS, but if I understood it right, VM’s tend to read/write relatively page-sized blocks (so 8K-ish). If so, having 1M blocksize and the VM asking for 8K r/w would lead to a very large read/write amplification.
