Hi all, my first post here. On my Internet server, I use this script daily to rotate snapshots:
for i in pool/home pool/www pool/local pool/share
do
# Get the snapshot directory
sdir=`df | grep $i | sed 's/.* //'`/.zfs/snapshot
# Unmount all the snapshots
for j in 0 1 2 3
do umount $sdir/daily.$j 2> /dev/null
done
# Shuffle the snapshots & make a new one
zfs destroy $i@daily.3 2> /dev/null
zfs rename $i@daily.2 $i@daily.3 2> /dev/null
zfs rename $i@daily.1 $i@daily.2 2> /dev/null
zfs rename $i@daily.0 $i@daily.1 2> /dev/null
zfs snapshot $i@daily.0 2> /dev/null
for j in 0 1 2 3
done
done
which makes and rotates, e.g. pool/home@daily.0 to .1, .2, .3.
I can ssh into the server as root as I have an authorized key set up. I want to be able to synchronise these snapshots to my NAS box at home, which is my own Linux box with ZFS working.
Issues: the mountpoint at home isn’t going to be the same as the mountpoint on the server. I also use port knocking, so each ssh command takes about a second to start, so I don’t want to use syncoid.
I’ve started to play with zfs send and zfs receive, but I’m a bit lost with all the options.
Could someone suggest a zfs send/receive pipeline to e.g. synchronise the pool/home snapshots on my server (mounted on /home) to my at-home pool8T/MinHome (mounted on /usr/MinSnap/home)?
Or, point me at some useful on-line resources?
Thanks so much! Warren
