Syncoid initial replication succeeds but all subsequent attempts fail with CRITICAL ERROR
Hello. I am in the process of trying out sandod/syncoid after using zfs-autobackup for a while. Sanoid appears to be doing it’s job correctly but I’m having some teething issues with Syncoid.
I am replicating in a push fashion from a server running FreeBSD 14.2-RELEASE to a server running FreeBSD 13.2-RELEASE-p11. They both have the latest version of sanoid installed, so neither end should be missing any dependencies. Note that I have not yet configured sanoid to actually run on the destination yet, so it is not doing anything with snapshots yet.
If I delete the dataset on the destination and run syncoid on the source, the full replication completes successfully:
[root@max ~]# syncoid --sshport=223 zroot/usr/local/etc pricetx@walt.chrisprice.co:zstore/backups/max/usr/local/etc
INFO: Sending oldest full snapshot zroot/usr/local/etc@autosnap_2025-03-11_18:09:56_monthly (~ 1.2 MB) to new target filesystem:
1.37MiB 0:00:00 [11.2MiB/s] [==============================================================================================================================================================================================] 118%
INFO: Updating new target filesystem with incremental zroot/usr/local/etc@autosnap_2025-03-11_18:09:56_monthly ... syncoid_max.jonathanprice.org_2025-03-13:09:32:59-GMT00:00 (~ 814 KB):
 847KiB 0:00:00 [1.74MiB/s] [==============================================================================================================================================================================================] 104%
However, if I then run the same command a second time, I would expect it to sync any changes, but instead it throws an error
Sending incremental zroot/usr/local/etc@syncoid_max.jonathanprice.org_2025-03-13:09:32:59-GMT00:00 ... syncoid_max.jonathanprice.org_2025-03-13:09:34:16-GMT00:00 (~ 4 KB):
1.52KiB 0:00:00 [3.93KiB/s] [=======================================================================>        ]  38%
CRITICAL ERROR:  zfs send  -I 'zroot/usr/local/etc'@'syncoid_max.jonathanprice.org_2025-03-13:09:32:59-GMT00:00' 'zroot/usr/local/etc'@'syncoid_max.jonathanprice.org_2025-03-13:09:34:16-GMT00:00' | pv -p -t -e -r -b -s 4096 | lzop  | mbuffer  -q -s 128k -m 16M | ssh    -p 223  -S /tmp/syncoid-pricetx@walt.chrisprice.co-1741858455-1153 pricetx@walt.chrisprice.co ' mbuffer  -q -s 128k -m 16M | lzop -dfc | sudo zfs receive  -s -F '"'"'zstore/backups/max/usr/local/etc'"'"' 2>&1' failed: 512 at /usr/local/bin/syncoid line 889.
Confusingly, if I take the zfs command that gets printed in the syncoid error output and run it directly it seems to complete successfully:
[root@max ~]# zfs send  -I 'zroot/usr/local/etc'@'syncoid_max.jonathanprice.org_2025-03-13:09:32:59-GMT00:00' 'zroot/usr/local/etc'@'syncoid_max.jonathanprice.org_2025-03-13:09:34:16-GMT00:00' | pv -p -t -e -r -b -s 4096 | lzop  | mbuffer  -q -s 128k -m 16M | ssh    -p 223  -S /tmp/syncoid-pricetx@walt.chrisprice.co-1741858455-1153 pricetx@walt.chrisprice.co ' mbuffer  -q -s 128k -m 16M | lzop -dfc | sudo zfs receive  -s -F '"'"'zstore/backups/max/usr/local/etc'"'"''
1.52KiB 0:00:00 [2.12KiB/s] [=======================================================================>
The cycle then repeats. If I try running syncoid again it throws the same error (albeit with new snapshot names), and then if I take the printed zfs send/recv command and run it myself it completes successfully.
I’m unsure what error 512, or indeed which application is even raising it.
I tried with other datasets too just to make sure it wasn’t an issue with this particular dataset, but the results are identical:
In-line copy of the above screenshot below:
[root@max ~]# syncoid --sshport=223 zroot/var/log pricetx@walt.chrisprice.co:zstore/backups/max/var/log
INFO: Sending oldest full snapshot zroot/var/log@autosnap_2025-03-11_18:09:54_monthly (~ 1.1 GB) to new target filesystem:
1.12GiB 0:00:25 [44.7MiB/s] [=============================================================================================================================================================================================>] 100%
INFO: Updating new target filesystem with incremental zroot/var/log@autosnap_2025-03-11_18:09:54_monthly ... syncoid_max.jonathanprice.org_2025-03-13:09:39:27-GMT00:00 (~ 156.5 MB):
 154MiB 0:00:05 [26.6MiB/s] [==========================================================================================================================================================================================>   ]  98%
Sending incremental zroot/var/log@syncoid_max.jonathanprice.org_2025-03-13:09:39:27-GMT00:00 ... syncoid_max.jonathanprice.org_2025-03-13:09:41:01-GMT00:00 (~ 568 KB):
 519KiB 0:00:00 [ 956KiB/s] [============================================================================================================================================================================>                 ]  91%
mbuffer: error: outputThread: error writing to <stdout> at offset 0x10000: Broken pipe
mbuffer: warning: error during output to <stdout>: Broken pipe
CRITICAL ERROR:  zfs send  -I 'zroot/var/log'@'syncoid_max.jonathanprice.org_2025-03-13:09:39:27-GMT00:00' 'zroot/var/log'@'syncoid_max.jonathanprice.org_2025-03-13:09:41:01-GMT00:00' | pv -p -t -e -r -b -s 582480 | lzop  | mbuffer  -q -s 128k -m 16M | ssh    -p 223  -S /tmp/syncoid-pricetx@walt.chrisprice.co-1741858860-1106 pricetx@walt.chrisprice.co ' mbuffer  -q -s 128k -m 16M | lzop -dfc | sudo zfs receive  -s -F '"'"'zstore/backups/max/var/log'"'"' 2>&1' failed: 512 at /usr/local/bin/syncoid line 889.
[root@max ~]# zfs send  -I 'zroot/var/log'@'syncoid_max.jonathanprice.org_2025-03-13:09:39:27-GMT00:00' 'zroot/var/log'@'syncoid_max.jonathanprice.org_2025-03-13:09:41:01-GMT00:00' | pv -p -t -e -r -b -s 582480 | lzop  | mbuffer  -q -s 128k -m 16M | ssh    -p 223  -S /tmp/syncoid-pricetx@walt.chrisprice.co-1741858860-1106 pricetx@walt.chrisprice.co ' mbuffer  -q -s 128k -m 16M | lzop -dfc | sudo zfs receive  -s -F '"'"'zstore/backups/max/var/log'"'"''
 519KiB 0:00:00 [ 650KiB/s] [============================================================================================================================================================================>                 ]  91%
[root@max ~]# syncoid --sshport=223 zroot/var/log pricetx@walt.chrisprice.co:zstore/backups/max/var/log        Sending incremental zroot/var/log@syncoid_max.jonathanprice.org_2025-03-13:09:41:01-GMT00:00 ... syncoid_max.jonathanprice.org_2025-03-13:09:41:59-GMT00:00 (~ 461 KB):
 403KiB 0:00:00 [ 887KiB/s] [=====================================================================================================================================================================>                        ]  87%
CRITICAL ERROR:  zfs send  -I 'zroot/var/log'@'syncoid_max.jonathanprice.org_2025-03-13:09:41:01-GMT00:00' 'zroot/var/log'@'syncoid_max.jonathanprice.org_2025-03-13:09:41:59-GMT00:00' | pv -p -t -e -r -b -s 472216 | lzop  | mbuffer  -q -s 128k -m 16M | ssh    -p 223  -S /tmp/syncoid-pricetx@walt.chrisprice.co-1741858918-2889 pricetx@walt.chrisprice.co ' mbuffer  -q -s 128k -m 16M | lzop -dfc | sudo zfs receive  -s -F '"'"'zstore/backups/max/var/log'"'"' 2>&1' failed: 512 at /usr/local/bin/syncoid line 889.
[root@max ~]#
Does anybody have any suggestions on how I might troubleshoot this further?
Thanks,
Jonathan
EDIT: Apologies, new accounts can only post one image per post, but the last image shows everything mentioned in the previous images anyway.
You can post pre-formatted text using Markdown (note, those are back ticks, not apostrophes):
```text
formatted text
You can probably include more than one.
As to the issue… It looks like you are mixing syncoid and zfs send commands and I wonder if something different in that usage is leading to the error. I usually use the same syncoid command (and parameters) for the initial (full) replication and subsequent (incremental) replications. Have you tried that?
Hi Hank,
Thanks for the quick reply, I’ve gone back and amended the original post with in-line console snippets to make the whole thing a bit easier to read.
To be clear, the aim is to let Syncoid do everything, I don’t want to complicate anything with doing any manual ZFS sending / receiving in addition to it, it’s just that the error message that Syncoid outputs includes the command that failed to run.
That is the command that I have tried running manually to try and recreate Syncoid’s error hoping that I would get a more detailed failure reason, but to my surprise it instead worked.
Let me know if there’s any other commands you would like to see, or if you’d like me to take another stab at explaining what I’ve tried so far as I appreciate it’s a bit confusing.
That’s a lot easier to parse. The line:
That seems to be the first indication of an error, no? Since it’s writing to <stdout> and not a port, I think it is on the receiving end, but the next statement (which I presume comes from the sending end) also says that so I could be mistaken. Or not. Looks like mbuffer is piping output to ssh on the sending side.
Are either of these hosts memory constrained? syncoid has a flag
      --debug               Prints out a lot of additional information during a syncoid run
that might be worth a try.
NB: I have a lot less experience with BSD so I could be barking up the wrong tree here.
You hit the nail on the head; this is either an issue with mbuffer itself under freebsd or, more likely, it’s the result of the user using a non-Bourne-compatible shell (like csh).
I put FreeBSD on a Pi 4B and was surprised to find the root shell was csh.
Aha! I had already thought about changing the shell, so the tests that I had run above had all been performed under bash. However, what I had failed to consider until now was checking what shell my user on the destination server was running. It was running TCSH. I have changed this to Bash and it now appears to be working both interactively and via cron.
[root@max ~]# syncoid -r --sshport=223 zroot/usr/local/etc pricetx@walt.chrisprice.co:zstore/backups/max/usr/local/etc
Sending incremental zroot/usr/local/etc@syncoid_max.jonathanprice.org_2025-03-14:06:44:28-GMT00:00 ... syncoid_max.jonathanprice.org_2025-03-14:06:46:11-GMT00:00 (~ 4 KB):
1.52KiB 0:00:00 [4.19KiB/s] [=======================================================================>        ]  38%
[root@max ~]#
Thank you for the support, Jim and all.
No problem. One note: bash is of course perfectly fine, but it’s not required. Any Bourne compatible shell–including Bourne, aka /bin/sh, itself–is perfectly fine!
(Requiring bash specifically is often seen as anti-FreeBSD, and I strove from the very beginnings not to exclude FreeBSD, so the distinction is important to me! :sweat_smile:)
Ha, it’s refreshing to see that stance for Bourne shell. Sure enough, testing /bin/sh on both ends works perfectly.
My FreeBSD self thanks you :smile:
