I have two syncoid jobs running on my main NAS machine, N
(real machine names elided for a false sense of privacy)
The first pulls the full filesystem from E, my elasticsearch/logstash/kibana
machine.
The second sends everything (including E’s backups) to a hot spare backup machine, B.
The setup looks like this:
E ← N → B
The systemd units look like the following:
syncoid-E.service
[Unit]
Description=Syncoid ZFS Recieve from E
Wants=syncoid-E.timer
[Service]
Type=oneshot
ExecStart=syncoid --no-privilege-elevation --no-sync-snap --sendoptions=p -r N@E:E-zroot N-pool/srv/machines/E
syncoid-B.service
[Unit]
Description=Syncoid ZFS Send to B
Wants=syncoid-B.timer
[Service]
Type=oneshot
ExecStart=syncoid --no-privilege-elevation --sendoptions=p -r N-pool/srv N@B:B-pool/srv
E is running ZFSBootMenu and has a dataset setup that closely follows their
recommended setup:
E# zfs list
E-zroot 3.62G 212G 96K none
E-zroot/ROOT 3.57G 212G 96K none
E-zroot/ROOT/debian 3.57G 212G 3.17G /
E-zroot/home 204K 212G 140K /home
Importantly, E’s datasets have the following canmount settings:
root@E:~# zfs get canmount E-zroot/ROOT/debian
NAME PROPERTY VALUE SOURCE
E-zroot/ROOT/debian canmount noauto local
root@E:~# zfs get canmount E-zroot/home
E-zroot/home canmount on default
When I first pulled E to N, I ended up in a situation where syncoid had mounted
over N’s /home, which I eventually resolved via crossing my fingers and rebooting,
then setting canmount=noauto on N-pool/srv/machines/E/home.
N# zfs get canmount N-pool/srv/machines/E/home
N-pool/srv/machines/E/home canmount noauto local
However, when N pushes to B, syncoid fails with the following error:
Dec 07 10:55:27 N syncoid[306103]: Sending incremental N-pool/srv/machines/E@autosnap_2024-12-06_03:00:05_hourly ... syncoid_N_2024-12-07:10:54:40-GMT-05:00 (~ 38 KB):
Dec 07 10:55:58 N syncoid[306107]: could not find any snapshots to destroy; check snapshot names.
Dec 07 10:55:58 N syncoid[306103]: WARNING: ssh -S /tmp/syncoid-N@B-1733586221 N@B ' zfs destroy '"'"'B-pool/srv/machines/E'"'"'@syncoid_N_2024-12-07:09:08:47-GMT-05:00' failed: 256 at /usr/sbin/syncoid line 1380.
Dec 07 10:56:43 N syncoid[306103]: Sending incremental N-pool/srv/machines/E/ROOT@autosnap_2024-12-06_03:00:05_hourly ... syncoid_N_2024-12-07:10:55:59-GMT-05:00 (~ 37 KB):
Dec 07 10:56:44 N syncoid[310622]: cannot receive org.zfsbootmenu:commandline property on B-pool/srv/machines/E/ROOT: permission denied
[REPEATED MANY TIMES, ELIDED]
Dec 07 10:57:13 N syncoid[306107]: could not find any snapshots to destroy; check snapshot names.
Dec 07 10:57:13 N syncoid[306103]: WARNING: ssh -S /tmp/syncoid-N@B-1733586221 N@B ' zfs destroy '"'"'B-pool/srv/machines/E/ROOT'"'"'@syncoid_N_2024-12-07:09:08:57-GMT-05:00' failed: 256 at /usr/sbin/syncoid line 1380.
Dec 07 10:57:58 N syncoid[306103]: Sending incremental N-pool/srv/machines/E/ROOT/debian@autosnap_2024-12-06_03:00:05_hourly ... syncoid_N_2024-12-07:10:57:14-GMT-05:00 (~ 558.8 MB):
Dec 07 10:58:51 N syncoid[311232]: cannot mount 'B-pool/srv/machines/E/ROOT/debian': Insufficient privileges
Dec 07 10:58:51 N syncoid[306103]: CRITICAL ERROR: zfs send -p -I 'N-pool/srv/machines/E/ROOT/debian'@'autosnap_2024-12-06_03:00:05_hourly' 'N-pool/srv/machines/E/ROOT/debian'@'syncoid_N_2024-12-07:10:57:14-GMT-05:00' | pv -p -t -e -r -b -s 585988952 | lzop | mbuffer -q -s 128k -m 16M 2>/dev/null | ssh -S /tmp/syncoid-N@B-1733586221 N@B ' mbuffer -q -s 128k -m 16M 2>/dev/null | lzop -dfc | zfs receive -s -F '"'"'B-pool/srv/machines/E/ROOT/debian'"'"' 2>&1' failed: 256 at /usr/sbin/syncoid line 817.
Dec 07 10:59:36 N syncoid[306103]: Sending incremental N-pool/srv/machines/E/home@autosnap_2024-12-06_03:00:05_hourly ... syncoid_N_2024-12-07:10:58:52-GMT-05:00 (~ 65 KB):
Dec 07 11:00:02 N syncoid[311878]: cannot mount 'B-pool/srv/machines/E/home': Insufficient privileges
Dec 07 11:00:02 N syncoid[306103]: CRITICAL ERROR: zfs send -p -I 'N-pool/srv/machines/E/home'@'autosnap_2024-12-06_03:00:05_hourly' 'N-pool/srv/machines/E/home'@'syncoid_N_2024-12-07:10:58:52-GMT-05:00' | pv -p -t -e -r -b -s 67360 | lzop | mbuffer -q -s 128k -m 16M 2>/dev/null | ssh -S /tmp/syncoid-N@B-1733586221 N@B ' mbuffer -q -s 128k -m 16M 2>/dev/null | lzop -dfc | zfs receive -s -F '"'"'B-pool/srv/machines/E/home'"'"' 2>&1' failed: 256 at /usr/sbin/syncoid line 817.
Permissions on N’s send user on B:
B# zfs allow B-pool/srv
---- Permissions on B-pool/srv ----------------------------------------
Local+Descendent permissions:
user N acltype,canmount,compression,create,destroy,mount,mountpoint,quota,receive,refquota,relatime,rollback,xattr
canmount on B:
B# zfs get canmount B-pool/srv/machines/E/ROOT/debian
B-pool/srv/machines/E/ROOT/debian canmount noauto local
B# zfs get canmount B-pool/srv/machines/E/home
B-pool/srv/machines/E/home canmount noauto local
How can I ensure that syncoid does not try to mount any of E’s datasets on B?
Do I need to setup a separate dataset (instead of using srv) for zfsbootmenu
machines (I intend to have more in the future)?
How can I avoid the property error with org.zfsbootmenu:commandline?
I was able to share all the normal ZFS properties as distinct permissions,
but I couldn’t find a permission for properties more generally.
