I am using Syncoid to copy an existing dataset called “tank/data1” to a target
system using the same pool/dataset name.
There seems to be a discrepancy between the used/Refer amounts between the
source and the target systems. The SOURCE shows 183G used and 169G refer. The
TARGET shows 253G used and 236G REFER.
I wanted to ask what would cause this significant difference between the
source and the target systems. Note, the transfer completes successfully.
LZ4 compression is on for both system pools
#SOURCE
tank/data1 183G 4.82T 169G /tank/data1 #TARGET
tank/data1 253G 5.6T 236G tank/data1
Source System:
zfs --version
zfs-2.1.5-1ubuntu6~22.04.1
zfs-kmod-2.1.5-1ubuntu6~22.04.1
OS: Ubuntu 22.04.3 LTS
Syncoid:
/usr/sbin/syncoid version 2.2.0
(Getopt::Long::GetOptions version 2.52; Perl version 5.34.0)
The two system disk sizes suggests that the two pools are not identical - this could affect the disk usage. Also it seems that it is the target system that takes up most room. This could be due to different retention rules - have you checked the number of snapshots?
You can also do a:
$ zfs list -o "name,used,usedds,usedsnap,avail,mountpoint"
The column Used Datasets should be the about the same, if the dataset has just recently been
sent
Actually, I forgot to mention that the target system is a brand new setup
and does not have any snapshot rules setup at all at this time; which is why the difference
surprises me. I would think that since the system is new and the syncoid transfer is
creating the data1 dataset on the target from scratch, that the copy totals would be a bit closer.
SOURCE SYSTEM:
NAME USED USEDDS USEDSNAP AVAIL MOUNTPOINT
tank/data1 183G 169G 13.9G 4.82T /tank/data1
TARGET SYSTEM:
So the source might purge older snapshots, which the target does not - that could be part of the reason for the difference, and then as Jim Salter says the pool topology, ashift and I guess possibly blocksize.
Mismatched ashift is the cause. Replication will not tear down blocks and rebuild them, so when the physical sector size (ashift) is different from one system to the next, you wind up with magically expanding data like this.
Changes in topology can have some effect also, but generally not as large as what you see here. I also discovered this the hard way, going from ashift=9 to a new ashift=12 pool… At least your sector size just doubled, instead of increasing by a factor of eight!
You either need to set ashift(target) = ashift(source), or if you want to permanently increase the sector size inside your blocks, do a brute force copy operation (eg rsync) instead of replication.
Note that ashift is immutable, so we’re talking about blowing the entire pool away and recreating from scratch. Sorry 'bout that.
I am wondering about your pool topology. First of all congrats on all NVMe - that is currenty just a dream for me
I do not know the roles of the two pools - they may both be primary pools that are used as backup/replication pools as a secondary role - also the sizes are not mentioned. RAIDZx optimal topology is datadisk 2-4-8-etc plus number of parity.
In your case the target is optimal 10 (8 data + 2 parity) where the source is non-optimal 8 (6 data + 2 parity). This may not be the cause of the size difference but may harm storage efficiency and performance.
Just out of curiousity, how do you connect 8 and 10 NVMe drives respectively?
