Syncoid very slow when transferring small datasets
Hello,
I use syncoid to transfer data between two servers on a gigabit LAN. The transfer speed is more than 100 MiB/s with larger datasets. However, with very small datasets (df says <20K) , the speed is very slow ~ 7KiB/s. Is there any way to speed the data-transfer for these small datasets?
Thanks
What you’re seeing isn’t actually “data transfer speed” it’s the speed of your pool in handling small metadata operations. I’m guessing your pool is rust.
Yes, both end are rust drives. Should i just flatten out all these datasets in a single dataset? The datasets are docker compose and volume files.
I can’t say if that’s what you “should” do, but it’s the only way you’re going to see replication speed up, short of moving to SSDs.
Replicating a ton of very small datasets instead of one large one is slow for the same reason copying 1GiB of 4KiB individual files goes (much, much) slower than copying a single 1GiB file would.
