Hi all, I am looking for a bit of troubleshooting guidance for (what is now) a fairly longstanding alert for excessive read latency on disks underlying a zfs mirror. I’ll preface this by saying that file systems and related topics are not something I’ve delved into and I have done little of this type of troubleshooting in the past, so I am likely missing some of the basics.
The hardware
I have a $5 Linode running a single service (Snikket) as a Docker container. Only family members use this service, so it sees very light traffic.
I added two block volumes to the vps, created a zfs volume and dataset, then moved the docker volumes to this dataset (so I can leverage zfs snapshots, etc.), as follows:
sudo apt install zfsutils-linux
sudo zpool create -f docker-pool mirror /dev/disk/by-id/disk-a /dev/disk/by-id/disk-b
sudo zfs create docker-pool/volumes
I have a Zabbix server for monitoring and an agent installed on this node.
The issue
I’ve had this node running for several months without issue. A couple months ago, at this point, I started getting an extremely annoying flapping alert for the “disk read request average waiting time (r_await).” I’ve fixed the flapping but not the large increase in wait time:
This screenshot is of just one of the block storage devices, but both report similar latency.
What (little) I’ve done so far
I haven’t spent much time on this issue, mostly because I didn’t know where to start. A bit of googling brought me to this article on using zpool iostat.
$ zpool iostat -vl
capacity operations bandwidth total_wait disk_wait syncq_wait asyncq_wait scrub trim
pool alloc free read write read write read write read write read write read write wait wait
docker-pool 4.19G 5.31G 4 84 36.4K 560K 2ms 914us 2ms 218us 5us 1us 375us 726us 53ms -
mirror-0 4.19G 5.31G 4 84 36.4K 560K 2ms 914us 2ms 218us 5us 1us 375us 726us 53ms -
scsi-0Linode_Volume_docker-data-1 - - 2 42 18.7K 280K 2ms 922us 2ms 220us 5us 1us 458us 731us 55ms -
scsi-0Linode_Volume_docker-data-2 - - 2 42 17.7K 280K 2ms 907us 2ms 215us 6us 843ns 302us 721us 50ms -
iostat -x returns:
Linux 5.15.0-116-generic (localhost) 08/18/2024 _x86_64_ (1 CPU)
avg-cpu: %user %nice %system %iowait %steal %idle
3.21 0.01 6.47 3.82 0.08 86.41
Device r/s rkB/s rrqm/s %rrqm r_await rareq-sz w/s wkB/s wrqm/s %wrqm w_await wareq-sz d/s dkB/s drqm/s %drqm d_await dareq-sz f/s f_await aqu-sz %util
loop0 0.00 0.00 0.00 0.00 0.17 3.11 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
loop1 0.00 0.09 0.00 0.00 0.44 33.76 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
loop2 0.00 0.00 0.00 0.00 0.17 6.12 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
loop3 0.00 0.00 0.00 0.00 0.56 15.86 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
loop4 0.00 0.00 0.00 0.00 0.22 3.05 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
loop5 0.03 0.25 0.00 0.00 0.10 7.24 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
loop6 0.00 0.00 0.00 0.00 0.13 5.97 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
loop7 0.00 0.00 0.00 0.00 0.20 6.14 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
loop8 0.00 0.00 0.00 0.00 0.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
sda 3.05 85.98 0.26 7.74 0.42 28.18 4.98 32.23 1.19 19.35 0.35 6.47 0.01 19.24 0.00 0.00 0.04 1403.62 0.47 0.12 0.00 0.42
sdb 1.20 6.17 0.34 22.02 0.24 5.13 0.36 5.48 1.01 73.64 2.31 15.18 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.12
sdc 3.23 18.73 0.00 0.00 10.87 5.79 42.46 280.07 0.00 0.00 0.14 6.60 0.00 0.00 0.00 0.00 0.00 0.00 0.98 30.73 0.07 4.39
sdd 3.57 17.69 0.00 0.00 10.10 4.96 42.41 280.07 0.00 0.00 0.14 6.60 0.00 0.00 0.00 0.00 0.00 0.00 0.98 30.94 0.07 4.51
Right now may not be the best example of the issue because things are pretty quiet, but I’m writing this now and it might be another couple months before I tackle it again, if I don’t finish it…
Even with the relatively low r_await from iostat, it’s still 5x higher than the total_wait for reads in zpool iostat; this disparity (if not the exact magnitude) has held true when r_await is much higher. My assumption is that these two measures would be related, but perhaps I’m mistaken.
Any pointers on additional steps to take are welcome. Thanks.
