Ubuntu VM freezing Console
Hi all,
Not sure if this is the right place to ask this but I have noticed on a couple of my servers running ubuntu server VM’s on top of a ubuntu server host with KVM that after a little while the console freezes. SSH still works, the shutdown button still works but using either virt-manager or cockpit-machines the console in the VM is frozen.
Any help would be greatly appreciated :slight_smile:
Warm regards,
If you have working SSH, you can run “journalctl” in follow mode to correlate the console freeze with error messages to begin troubleshooting:
journalctl -f -o short-iso
For example, years ago I had a similar situation with a QEMU-KVM host. Everything worked fine on the host, all the guests continued to run without issue, SSH was working, but the host screen locked/froze. In my case, it turned out to be my stubborn use of the Nouveau video driver, and I would see something like the following:
kernel: [14690.709515] nouveau 0000:02:00.0: gr: TRAP ch 4 [007f5a3000 Xorg[1435]]
I fixed it by switching from the somewhat open source Nouveau driver to the proprietary Nvidia driver.
Hope that helps!
