Hello,
Recently, I started using ZFS on my NixOS laptop.
Also, I started using ZFS on my external hard drive that I use for backup.
I successfully made a backup of my encrypted datasets and used incremental sending of snapshots.
After that, I decided I want to rename my snapshots to follow ISO 8601 date format.
Which I did on both my laptop and on my external hard drive.
However, after that I was not able to send incremental snapshots.
rpool is the pool that I use on my laptop, extpool is the pool on my external hard drive.
Here’s the list of my datasets:
[root@hp-laptop:~]# zfs list
extpool 328G 571G 24K /extpool
extpool/dataset-1 162G 571G 162G /extpool/dataset-1
extpool/hp-bak-enc 166G 571G 99K /extpool/hp-bak-enc
extpool/hp-bak-enc/home 166G 571G 162G /extpool/hp-bak-enc/home
rpool 181G 261G 24K none
rpool/enc 181G 261G 98K none
rpool/enc/home 166G 261G 161G legacy
rpool/enc/nix 14.7G 261G 14.7G legacy
rpool/enc/root 171M 261G 171M legacy
Here’s the list of my snapshots:
[root@hp-laptop:~]# zfs list -t snapshot
extpool/hp-bak-enc@--head-- 83K - 95K -
extpool/hp-bak-enc/home@2024-07-21_original_backup 2.86G - 162G -
extpool/hp-bak-enc/home@2024-07-21_backup_after_cleaning 7.24M - 160G -
extpool/hp-bak-enc/home@2024-07-22 11.2M - 162G -
rpool/enc/home@2024-07-21_original_backup 2.86G - 162G -
rpool/enc/home@2024-07-21_backup_after_cleaning 7.25M - 160G -
rpool/enc/home@2024-07-22 81.1M - 162G -
rpool/enc/home@2024-07-22_before_playing_with_thunderbird 6.78M - 162G -
rpool/enc/home@2024-07-24_after_fixing_thunderbird 21.0M - 162G -
rpool/enc/home@2024-07-27_before_deleting_cache_dir 344M - 162G -
Here’s the command I used for sending the snapshots:
[root@hp-laptop:~]# zfs send -v -w -I @2024-07-22 rpool/enc/home@2024-07-27_before_deleting_cache_dir | zfs receive extpool/hp-bak-enc/home
send from @2024-07-22 to rpool/enc/home@2024-07-22_before_playing_with_thunderbird estimated size is 242M
send from @2024-07-22_before_playing_with_thunderbird to rpool/enc/home@2024-07-24_after_fixing_thunderbird estimated size is 57.1M
send from @2024-07-24_after_fixing_thunderbird to rpool/enc/home@2024-07-27_before_deleting_cache_dir estimated size is 272M
total estimated size is 571M
TIME SENT SNAPSHOT rpool/enc/home@2024-07-22_before_playing_with_thunderbird
cannot receive incremental stream: destination extpool/hp-bak-enc/home has been modified
since most recent snapshot
Maybe this problem is not related to renaming snapshots at all, since this is my second time that I’m doing incremental sending at all…
Thanks a lot!
