Hi all,
I’m planning to migrate off a degraded RAIDZ1 pool on aging hardware (SmartOS global zone, ~7 years old) and would appreciate input on the cleanest way to do this.
I’ll be adding 3x new 4TB SATA enterprise disks (likely Seagate Exos), and the plan is to:
- Create a new pool with the new drives (RAIDZ1)
- Migrate all data from the current
zonespool - Preserve existing dataset structure and mountpoints
- Retire the old pool
Is zfs send the best (and only) proper way to do this migration on SmartOS, especially for datasets like zones and images? Can I do that in a way that the new pool is called zones as well in the end? Ideally SmartOS would just accept the new pool after the migration.
Anything I should watch out for?
Also, would anyone advise against the Seagate Exos drives for this use? Didn’t buy new hardware for a while…
Thanks,
Adrian
