ZFS Replication Compression options?
I’ll admit it. I have painted myself into a corner.
I’m currently using a Hetzner “Auction server” with 2 4T disks hanging off of it as my backup destination, and it works great.
But I expect that my source data sets will grow through the years. It’s the whole reason I switched to a “real” NAS because my 4T NAS was constantly filling up.
So my Hetzner server has ~500GB free, and I am on borrowed time.
With my old Synology, their “hyperbackup” tool would compress the source data down dramatically on the destination. the ~ 4T if memory serves on the source compressed down to less than 1T in Backblaze B2.
Are there any magic levers I can pull to achieve the same thing with ZFS? I already set the compression on the backup zpool to zstd.
root@rescue /backuppool # zpool list -v
NAME         SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP    HEALTH  ALTROOT
backuppool  3.62T  3.07T   569G        -         -     6%    84%  1.00x    ONLINE  -
  mirror-0  3.62T  3.07T   569G        -         -     6%  84.7%      -    ONLINE
    sda     3.64T      -      -        -         -      -      -      -    ONLINE
    sdb     3.64T      -      -        -         -      -      -      -    ONLINE
zfs get compressratio for the dataset(s) in question, please?
root@rescue ~ # zfs get compressratio backuppool
NAME        PROPERTY       VALUE  SOURCE
backuppool  compressratio  1.01x  -
Thanks for the response!
Yep, that’s what I expected. That’s not compressed, at all. Compression only takes effect at file creation, essentially.
Basically the answer here is… not something you’re gonna like. You need to destroy the existing backup, zfs create backuppool/backups ; zfs set compress=zstd backuppool/backups ; THEN you can perform a new full replication from source to target eg syncoid -r root@source:sourcepool backuppool/backups/sourcepool.
This way, the newly created (by inbound replication) datasets will inherit the compression setting on the backuppool\backups dataset, and you’ll get the compression you’re looking for.
If all you wanted to do was compress the data where it lies, you’d have some other options–but they’d break the replication chain. Starting over with a full targeted to the child of a dataset with compression already enabled is the only way to get the data compressed without the next replication wiping out the change.
Alternately, if you’ve got an older common snapshot between source and target, you can create your new dataset with compression enabled, do local replication from the current datasets to children of the new backups dataset, then destroy the original and retarget your normal replication when you’re done.
But the ONLY way to make that work is with replication–not individual copies–and you said you’re already very close to your storage capacity limit, so you don’t have many options.
Another option to avoid breaking the replication chain: zfs detach one drive from your mirror vdev, create a new pool using that drive, and use that as a mule to get things re-jiggered locally on the target. Once you’re done, verify everything is correct, verify it again, then destroy the old pool and zfs attach its drive to the singleton on the new pool, and Bob will be thy nuncle.
Nah, deestroying and re-creating the backup ds is just fine.
I was contemplating options like having to ditch afs backups entirely and use an S3 like thing so this is gentle by comparison. Thank you!
(When you try something for the first time you’re foolish if you think you’re gonna get it just perfect without iterating a bit!)
What about using zfs rewrite to add compression to an existing dataset:
zfs set compression=zstd tank/dataset
zfs rewrite -P tank/dataset
With this you could compress source and destination. All snapshots will stay intact. And subsequent send/receive will then compress automatically.
Right. In other words, he would need to have enough space for both copies of his data, the old uncompressed copy and the new compressed copy, simultaneously.
Which he doesn’t. :upside_down_face:
He does not indeed!
I think Jim’s solution is the right answer here. I am not at all precious about my backup data, especially since the Hetzner server doesn’t seem to care about egress/ingress fees.
TBH I’m grateful that this is a thing. I rather thought I was SOL.
Adulting with your NAS is the gift that keeps on giving.
Wow, perhaps it’s a good thing I installed TrueNAS, as I appear to not be tall enough to properly ride this ride :slight_smile:
I destroyed and re-created the pool, and then set compression, I thought following the pattern you suggested. Here’s the shell history:
  168  zfs destroy backuppool/received-backups -r
  169  zfs create backuppool/received-backups
  170  zfs set compress=zstd backuppool/backups
  171  zfs set compress=zstd backuppool/received-backups
However I wasn’t smart enough apparently to check that I had compression set? Because after weeks the replication to Germany finally completed again, and again I see it’s taking the full 3G:
root@rescue ~ # zfs get compressratio backuppool/received-backups
backuppool/received-backups  compressratio  1.01x  -
root@rescue ~ #
So obviously I zigged when I should have zagged.
Any thoughts on where/how I went wrong here?
Thanks in advance for your patience.
What’s compressratio on the source look like?
deepthought% zfs get compressratio nas_general
nas_general  compressratio  1.01x  -
deepthought%
Note I’ve got plenty of room on the source disks.
Well, not real surprising that you’ve got the same compressratio on both source and target. Forget the target until you see a better ratio on the source.
If you’re CERTAIN that the data in question should be reasonably compressible, the next thing to try is (assuming your data is currently in nas_general/dataset1):
# zfs create nas_general/dataset2
# zfs set compress=zstd nas_general/dataset2
# cp -a /nas_general/dataset1 /nas_general/dataset2
Then you can zfs get compressratio nas_general/dataset2. If it’s still not better than 1.01x, we’re going to need to look closely at whether or not that data is actually compressible.
Minor point to the above discussion:
If the data is compressible, and the target has a suitable compreasion set, do not use raw sends when doing the replication.
This means that ZFS encryption keys need to be loaded on both source and target.
Also, if your data on the source system is not compressible, is that because you have (non-ZFS) encrypted containers stored there, or already-compressed media files? If so, you wont get any meaningful compression.
I’m not absolutely certain of anything - I guess I’d need to try compressing all the data…
I think what all of this is telling me is that I need to:
A) Get more disk added to the Hetzner instance as a short stop and
B) Figure out whether there might ever be any easing of storage prices or whether this is an eternal spiral upward. I know the right answer is to spend the $800 and go zfs.rent but I just can’t justify that this instant with my wife between contracts.
Thanks for all the feedback and consultation. It’s sincerely appreciated.
