Absolute ProxMox n00b here, with little linux experience but a good amount of Windows experience (Sysadmin for 25+ years)
I’m trying to troubleshoot what is probably a fairly basic networking configuration issue - hoping someone can steer me in the right direction!
I got some pointers from this post by @bladewdr but am not sure yet whether that has anything to do with my issue, I’m starting to think not…
I’m running a lenovo mini desktop with a Realtek PCIe Gbe family NIC
1 x NVMe 250GB with Windows 11
1 x SATA Samsung 2.5" SSD via mobo SATA connector with Proxmox 8
Networking works fine in windows, and works initially upon first install in Proxmox 8
Router has a DHCP reservation for the Lenovo for 192.168.2.8 but I also specify the same static IP during proxmox install just to be safe
After first install and an update, I can connect via HTTP to the management interface and can see:
My /etc/network/interfaces:
auto lo
iface lo inet loopback
iface enp3s0f0 inet manual
auto vmbr0
iface vmbr0 inet static
address 192.168.2.8/24
gateway 192.168.2.1
bridge-ports enp3s0f0
bridge-stp off
bridge-fd 0
… and lspci displays the following:
root@proxmox:~# lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
... <snip>
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 7
01:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 43ef
01:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] 500 Series Chipset SATA Controller
01:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] 500 Series Chipset Switch Upstream Port
02:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0e)
04:00.0 Non-Volatile memory controller: Sandisk Corp WD Black SN770 NVMe SSD (rev 01)
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Cezanne [Radeon Vega Series / Radeon Vega Mobile Series] (rev da)
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
root@proxmox:~#
All is as you would expect, and there is no sign of an issue with the NIC or driver.
So, I then shutdown, plug in the RAID adapter and upon booting up things look normal, however, I can no longer connect to the management interface remotely and pinging the router (192.168.2.1) from the Proxmox local console gives me a DESTINATION HOST UNREACHABLE error.
Rebooting back to the Windows NVMe drive and the network card takes about 20 seconds to sort itself out but then I get an insertion light come on in the switch and everything is fine.
At that time Using lspci I can see the following changes (first line new entry):
01:00.0 RAID bus controller: Hewlett-Packard Company Smart Array Gen8 Controllers (rev 01)
02:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Device 43ef
02:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] 500 Series Chipset SATA Controller
02:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] 500 Series Chipset Switch Upstream Port
03:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 43ea
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0e)
05:00.0 Non-Volatile memory controller: Sandisk Corp WD Black SN770 NVMe SSD (rev 01)
I then tried typing lspci -v -s 04: to enunciate the resources on that part of the bus and got a bunch of info including:
Kernel driver in use: r8169
Kernel modules: r8169
This was what put me onto the forum post I listed at the top, but when i tried to carry out the deb command in step 2 I get a BASH error telling me the command doesn’t exist.
I have tried editing /etc/network/interfaces and rebooting as follows:
auto lo
iface enp4s0f0 inet manual
auto vmbr0
gateway 192.168.2.1
bridge-ports enp4s0f0
bridge-stp off
bridge-fd 0
… to match the updated PCIe bus resource addressing but it doesn’t seem to fix the issue.
As a complete proxmox n00b I have no idea what else to try. Is the problem likely from the Realtek driver or have I missed another file where I need to update to account for the change to the PCIe bus? Any suggestions very gratefully received
